tv problem.
Old Apr 26, 2006 | 06:49 PM
sony224422's Avatar
Default tv problem.
Im not sure what brand tv i have but its a TFT screen i believe, with the power, ground and vid in all connected to the same spot on the TV. I have it on a switch with a house dvd player running from a DC/AC converter. The problem is that while watching a movie the top part of the screen goes fuzzy and sideways, but the rest is fine. I have tried different dvd players and such but its always the same. Anyone have any idea whats up with it? I have not tried a new ground, but i have tried moving the tv away from everything else electrical.
Old Apr 26, 2006 | 09:22 PM
dcautogroup's Avatar
well some times the power inverters put out bad voltage how many watts is the inverter you need at least 300-400watts sound like over kill but i have had it happen ..... acouple of times try that
and let me know good luck
Old Apr 27, 2006 | 06:24 AM
keemosaki's Avatar
Default Re: (dcautogroup)
yup. Usually the screen is okay, the source is all fudged up. And where are you plugging the power invertor to and where are you drawing the power for the lcd screen? if it is the same source under a same fuse, your gonna run into problems.
Old Apr 27, 2006 | 07:42 AM
sony224422's Avatar
Default Re: (keemosaki)
the power inverter is pluged into a cig lighter i put in, and the tv is running on a line seperate from that. Its on a line directly to the battery, but the ground is the same as the cig lighters. I'll try running another ground and a another power, because i think there are other things on the power wire too.
Old Apr 27, 2006 | 01:48 PM
94_DC4's Avatar
Default Re: tv problem. (sony224422)
What you need is a video amplifier. It will solve this simple problem. If u need more help then just IM me.
nicolaselias
Oct 19, 2011 12:47 AM
grilledcheese33
Audio / Security / Video
Jul 23, 2008 08:43 AM
dansquared
Oct 23, 2003 01:04 PM
