turn off capacitor?
Old Mar 24, 2008 | 02:27 PM
Blahblah718293's Avatar
Default turn off capacitor?
alright so i just got a capacitor for my subs, and my only question is: its one of those that displays voltage, but even when car and all acessories are off, it keeps the display on, should i worry about this draining my battery? or did i wire it wrong or somthing? its just grounded, then positive in series with the amp power wire.
Old Mar 24, 2008 | 02:59 PM
fcm's Avatar
fcm
Old Fart
Default Re: turn off capacitor? (Blahblah718293)
What is the make and model of cap, there should be a 3rd terminal, a small one for the HUs amp turn on lead, so display is only on when HU is on. 94
Old Mar 24, 2008 | 03:01 PM
nsxxtreme's Avatar
I dont know what kind of cap you have but the display should have a remote wire of some sort.
When I hook Caps up I also use a relay to cut power to the cap. Every cap made leaks current. Extended periods of time with the car off can drain the battery.
Old Mar 24, 2008 | 03:43 PM
Default Re: turn off capacitor? (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> What is the make and model of cap</TD></TR></TABLE>
its a pyramid CAP160DBL 1.6 farad, ebay trash, i know. i thaught id looked into them well enough.
no there isnt a remote wire. i only noticed the 2 big terminals.
a relay is an excellent idea, i dont know much about what relays do what, so what kind of size or type should i get for that?
and thank you for your help so far.
(edit) also: as for the relay, should it be wired to the power or ground side? i would assume power, but i just wanna get everything right here.
Old Mar 25, 2008 | 06:39 AM
fcm's Avatar
fcm
Old Fart
Default Re: turn off capacitor? (nsxxtreme)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxxtreme &raquo;</TD></TR><TR><TD CLASS="quote">When I hook Caps up I also use a relay to cut power to the cap. Every cap made leaks current.</TD></TR></TABLE> What????
That would mean if the cap discharges, [not connected for a period of time, it would instantly charge every time the relay is energized, and what size, [amperage] relay are you using? 94
Old Mar 25, 2008 | 07:15 AM
nsxxtreme's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> What????
That would mean if the cap discharges, [not connected for a period of time, it would instantly charge every time the relay is energized, and what size, [amperage] relay are you using? 94</TD></TR></TABLE>
It "instantly" charges everytime the amp discharges it. Caps are made to charge and discharge instantaniously.
We are talking large relays here 100A. In fact I believe some of the larger cap manufacturers supply relays like alumapro 15 Farad caps if I am not mistaken come with relays.
doggworld1233
Audio / Security / Video
26
Jan 2, 2017 04:01 PM
patrick4588
26
Jun 17, 2008 08:10 AM
thatasiankidtony
11
Apr 5, 2007 01:53 PM
R Thizzel
17
Nov 22, 2004 05:48 PM
ackerjack
Jul 24, 2004 07:02 AM
