Turbo timer with alarm question.
the car is a 2002 honda accord installed the turbo timer using this link here (http://importnut.net/turbotimer.htm) i know that this is for civic and integras but the ignition switch is close to the same wire color. Ive splice the GRN wire to the BLK/YEL wire, RED wire to the WHT wire, and BLUE wire to the YEL wire. Checked the voltage on all the wires and they are correct. my question is this, when the turbo timer is activated and i take the key out of the ignition, the car shuts off and turns back on again with the turbo timer counting down (set at 30 sec) then shuts off again. is it because i need to install a relay to bypass the alarm or is the turbo timer wiring messed up? the turbo timer is Apexi (the pen kind) and alarm is a Viper dont know the model.
What do you mean, "the car shuts off and turns back on again with the turbo timer counting down (set at 30 sec) then shuts off again" are you saying the engine stops running when you remove the key and then restarts by itself???4
