Turbo timer with alarm.
Old Apr 3, 2002 | 06:42 PM
Mase's Avatar
Default Turbo timer with alarm.
My alarm used to arm by itself after 30 seconds after i turned off the ignition. I turned that feature off, and now since i added my turbo timer, i decided to turn that feature back on, so all i would have to do is lock my door when i was getting out of the car and then the alarm would turn on after 30 seconds, when i activated this feature, for some reason it will not arm itself when i turn the ignition off, if i arm it with my remote, and disarm it with the remote, then it will arm itself again after 30 seconds, im guessing adding the turbo timer did something to this, does anyone know how to get around it? its an audiovox alarm if that helps any.
Old Apr 3, 2002 | 08:54 PM
t's Avatar
t
Default Re: Turbo timer with alarm. (CDooMe2)
You will have to go back to whoever you got to install your turbo timer or alarm to help you add a relay. Than all would be fine again.
mrm1ke02
Audio / Security / Video
Sep 18, 2007 11:00 AM
Boostless97Lude
Nov 4, 2005 12:36 PM
iRIDEdumped
Apr 29, 2005 06:34 PM
boostincoupe
Jul 8, 2003 07:19 AM
CRX SiR T
Jan 9, 2003 05:39 PM
