Trunk sensor
Old Oct 3, 2005 | 08:58 AM
DailyBlown's Avatar
Default Trunk sensor
Can anyone give me a diagram of which wire to tap into for the trunk sensor on a '92 Civic HB CX for audiovox alarms?
Old Oct 3, 2005 | 10:09 AM
B18C_EJ8's Avatar
Wire is green/black with silver dots. Located in a blue connector above the fusebox.
Old Oct 3, 2005 | 12:47 PM
fcm's Avatar
fcm
Old Fart
Default Re: Trunk sensor (DailyBlown)
May just be green w/ silver dots, about the middle of bottom row on blue connector 94
Old Oct 3, 2005 | 12:54 PM
B18C_EJ8's Avatar
Tsk tsk.. That's not what Directechs says... lol
Check both wires...
Old Oct 3, 2005 | 02:36 PM
fcm's Avatar
fcm
Old Fart
Default Re: (B18C_EJ8)
On a Civic 4 door, there is no green/black, [Canadian] don't know if it's the same down there, but I gave that info, [Direct Wire Honda Civic 1992] to someone that asked before and was told I must be wrong because he could not find it, also he could not find the L green/red in the gray plug behind kick panel for doors, it just happens my sister has a 92 4 door so I went and looked, guess what the trunk wire was just green w/ silver dots, right where the green/black was supposed to be and the L green/red door was a thick green/blue wire on the gray plug, I posted that back to him and he said he found them right away.
That is why there is a 6 -7 line disclaimer at the end of the Direct Wire sheet as is the case with most wire info, they all tell you to check and that they do not guarantee that the info they give you is correct all the time.
I understand that Honda/Acura more then anybody else stick to there wiring color codes, but I also know that if they ran out of green/black or L green/ red, somebody will get ****, but they are not going to stop a production run just for that, when they have wire that will do the job just as well.
I have only seen this on 4 door Civics, and heard about the one down in the US, the guy I gave the info to, I have not seen it on any other wire info sheets.
So if DailyBlown's 92 hatch wires match the Directechs Direct Wire sheet or Bulldogs http://www.bulldogsecurity.com...s.htm or any of the rest out there then no biggy, but if it does not, I just gave him another option to try. 94
Old Oct 4, 2005 | 03:57 AM
B18C_EJ8's Avatar
Dang! Was just playin...
Old Oct 4, 2005 | 06:54 AM
fcm's Avatar
fcm
Old Fart
Dang, was just playing back. 94
Old Oct 4, 2005 | 06:58 AM
B18C_EJ8's Avatar
I know... Just shocked by the 40 minute dissertation on trunk sensor wires...
Old Oct 4, 2005 | 07:51 AM
fcm's Avatar
fcm
Old Fart
NA, only about 15 min., and it may help if/when somebody uses search 94
Old Oct 4, 2005 | 07:56 AM
B18C_EJ8's Avatar
Good call!
Old Oct 4, 2005 | 05:27 PM
db8xc1x39
Guest
Posts: n/a
Default Re: Trunk sensor (fcm)
DirecTechs is the shiet!
Old Oct 5, 2005 | 11:38 AM
fcm's Avatar
fcm
Old Fart
Default Re: Trunk sensor (db8xc1x39)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by db8xc1x39 &raquo;</TD></TR><TR><TD CLASS="quote">DirecTechs is the shiet!</TD></TR></TABLE> Aaaa, I forgot, does that mean good or bad? 94
Hockey_dad44
May 20, 2013 05:22 PM
SilverEK96
Audio / Security / Video
Jun 6, 2012 03:54 PM
classicalgq
Aug 4, 2008 10:12 AM
BDogggUT34
Aug 17, 2005 01:25 PM
DocYahoo
15
Jul 20, 2002 04:29 PM
