Theft Proof Security for Amps!
Old Jan 3, 2003 | 09:57 PM
greyzone's Avatar
Default Theft Proof Security for Amps!
This should stop the bastards!
Picture 1: Steel straps are form fitted to cover amps. Then double wrapped in electrical tape with foam padding on bottom side to cushion against amp.
Picture 2: Amps are placed under the seats, holes are then drilled through floor, using 3/8 bolts with large washers and bolted from underneath car. Amps cannot be removed without steel straping being removed first.
Pictures 3 and 4: Nuts and bolts are welded from underneath, they are NOT coming off unless cut off with a die grinder.
After two thefts in one year I've had it!!!!!!!!! Bastards!!!!!!!!!! These amps are NOT going anywhere....of course, now they might steal the whole car.....
[Modified by greyzone, 12:11 PM 1/4/2003]
[Modified by greyzone, 5:34 PM 1/5/2003]
Old Jan 4, 2003 | 02:42 AM
vteg's Avatar
New User
Default Re: Theft Proof Security for Amps! (greyzone)
Woah
Old Jan 4, 2003 | 05:26 AM
t0p_sh0tta's Avatar
Default Re: Theft Proof Security for Amps! (vteg)
WoW.... thats hardcore, I'd hate to blow a fuse or have a wire come loose. ******' thieves
Old Jan 4, 2003 | 06:16 AM
greyzone's Avatar
Default Re: Theft Proof Security for Amps! (t0p_sh0tta)
HaRDcore is right! Im tired of softball with these dicks that cant get a life and have to take ours!
THe main draw back is when i need to remove them. I gotta go back to the shop and have them cut off on a lift with the damn die grinder....but at least no slimy drug seeking theif is gonna walk off with my stuff!
Bastards! (Sorry, im just a weeeeEEEEEE bit pissed...and this is only ONE of several NEW security measures Im am taking)
[Modified by greyzone, 7:17 AM 1/4/2003]
Old Jan 4, 2003 | 10:25 AM
redwinqs's Avatar
i did that too...but without the metal straps...just bolted down the amp under one of my seats...
Old Jan 4, 2003 | 10:30 AM
greyzone's Avatar
Default Re: Theft Proof Security for Amps! (redwinqs)
problem with that is you put a pry bar under the amp and it pops right out....amps gone in 60 seconds. Maybe they have to remove the seat first but whats that take, 4 bolts?
under the seat is one thing, bolted with steel straps and welded is another. im trying to do what i can.
Old Jan 4, 2003 | 12:38 PM
Fr0m4311's Avatar
Good idea but can't you just slide the amp out one of the side?
Old Jan 4, 2003 | 12:55 PM
greyzone's Avatar
Default Re: Theft Proof Security for Amps! (Mad_hatter)
The bigger amp, even with the seat removed, cannot slide out. There is simply not enough room. It would either hit the door jam/carpet rise, or the center console, so two straps across was good for that one. Plus, the steel straps are extremely tight, there really is no "sliding them out" unless the straps are removed first.
But, just in case, on the smaller amp, I used a cross pattern. Otherwise, i think this is about the best way to keep the amps from being taken...at least "quickly." Whatever they do will trigger my alarm, my pager will go off, and im out there in 60 seconds tops anyway...they aint getting these amps out in 60 seconds.
Old Jan 4, 2003 | 01:36 PM
vteg's Avatar
New User
I like the idea. I will use it once I find a good theft resistant bolt to accompany it. I found this From the description it looks round but is really oval and requires a special driver to remove it. They don't sell oval nuts though. They sell a nut cover that is very difficult to remove and and this one which looks close to impossible to get out
Old Jan 4, 2003 | 02:06 PM
TurboBumblBee's Avatar
good idea man.. but those steel staps can be cut w/ tin snips or bolt cutters w/ no problem at all.. we have cut interior doors so that speakers can fit in my shop using tin snips w/ no problem, im sure your straps arent that strong..
good thinking tho bro.. u gotta think of it this way, if they want your car or parts bad enough they can and will get them..
Old Jan 4, 2003 | 03:17 PM
95CoupinIt's Avatar
Holy ****!!!! WTF is that guy welding without a helmet?????
Old Jan 4, 2003 | 03:25 PM
greyzone's Avatar
Default Re: Theft Proof Security for Amps! (95CoupinIt)
yeah, i was thinking about the tin snips/bolt cutter angle...gotta come up with something for that.....damn....but i've got another idea brewing that i think will take care of that....
And yeah, no helmet or even goggles...said he was just looking "behind" the flame nozzel and not at it, that he just needs to be careful where he looks...not for me tho...
Old Jan 4, 2003 | 09:24 PM
t0p_sh0tta's Avatar
How much do they charge to do something like that? To me, security screws for the most part are a waste. I've never seen a thief take to time to "uninstall" something. Its usually just a ****** and run.
Old Jan 4, 2003 | 09:40 PM
greyzone's Avatar
to do something like what??
and yes, security screws are a joke, its just about smash and grab to a theif
[Modified by greyzone, 10:41 PM 1/4/2003]
[Modified by greyzone, 10:42 PM 1/4/2003]
Old Jan 5, 2003 | 12:16 AM
vteg's Avatar
New User
For that particular company the bolts ranged from 8 to 14 mm. No smash and run. How would you stop tin snips? I don't think snips could make it through if the bars were over a couple of mm thick.
Old Jan 5, 2003 | 07:50 AM
t0p_sh0tta's Avatar
What are they charging to install the amps, or are you doing it yourself?
Old Jan 5, 2003 | 08:09 AM
greyzone's Avatar
doing this myself...you know, if you want it dfone right type of thing...and its taking so long to do this custom work i'd be paying a small ransom for everything im doing (this is just a small part)...i've rewired and reconfigured my dash, gauges, heater/AC switch placement...and more...all designed to slow the thieves down and make their job more difficult...my goal, in part, they may damage my stuff trying to get it out, but they aint gonna get it!
[Modified by greyzone, 9:12 AM 1/5/2003]
Old Jan 5, 2003 | 08:55 AM
Hcivic88's Avatar
holy ****.... those things aren't going nowhere, lol.
looks like your bigger amp is on a slight angle though, too late now though...
even with tin snips, those brackets would be pretty hard to cut, cause you'd have to cut through the padding and electrical tape and stuff. still, it would take them quite some time to cut both the straps. and by then, you'd probably catch them
Old Jan 5, 2003 | 01:48 PM
Lou_Cypher's Avatar
Default Re: Theft Proof Security for Amps! (Hcivic88)
question; why not design an amprack subwoofer enclosure into the spare well that can be totally stealth but not a headache to remove?
all that welding could be done to make bolts locking down the compartment where the spare tire resided as a locked type of cabinet
Old Jan 5, 2003 | 04:30 PM
greyzone's Avatar
Default Re: Theft Proof Security for Amps! (Lou_Cypher)
seems to me like that would be even more work, not less...and more costly. THe straps are pretty quick and easy, just that I now realized I need better from fitted and thicker steel, but this wasnt bad for a first pass.
Plus, i like having easy access to the amps as far as tuning, so i can be in the car and tune at the same time...couldnt do that with them in the spare well...and if bolts were welded there would be no access to the amps to tune them, etc.
[Modified by greyzone, 5:35 PM 1/5/2003]
Old Jan 5, 2003 | 06:33 PM
integra-modder's Avatar
Thats some interesting stuff....where are you getting it from?
Old Jan 5, 2003 | 06:41 PM
EFsleeper's Avatar
Default Re: Theft Proof Security for Amps! (integra-modder)
thats fine and dandy if you want to drill some holes and make it look crappy but whatever works for you...
Old Jan 5, 2003 | 06:43 PM
nsxxtreme's Avatar
get some 1/8 or 1/4 inch straps made then they won't go anywhere.
Old Jan 5, 2003 | 06:47 PM
EBP_SI's Avatar
Aren't you worried about your amps getting dirty of having stuff spilled on them??
i mean look at your carpet....It's not exactly spotless
Old Jan 5, 2003 | 08:02 PM
Default Re: Theft Proof Security for Amps! (EBP_SI)
Haha, i thought about that except i didnt want to come off as a dick saying that...
