Testing a Radio
Old Jun 18, 2003 | 11:51 PM
TypeR 599's Avatar
Default Testing a Radio
I have a radio that's not in the car, I want to test to see if it works. how do i do that? thanks
Old Jun 19, 2003 | 12:12 AM
ted97dx's Avatar
Default Re: Testing a Radio (TypeR 599)
1. get a 12 volt power supply from radio shack.
2. get some black and red wire and small alligator clips too.
3. hook up black wire to negative of power supply and negative on radio
4. hook up red wire to positive of power supply and positive on radio
5. you can also hook ithe radio up to a speaker to test for sound
Old Jun 19, 2003 | 05:02 AM
t0p_sh0tta's Avatar
Default Re: Testing a Radio (ted97dx)
Too much work (and money). Connect it directly to the battery. All you need is the yellow (positive) power wire, and the ground. Touch them to the battery terminals and hook up a speaker.
Old Jun 19, 2003 | 08:10 AM
Xsi's Avatar
Xsi
I found that my computer scanner had an input of 12 V DC so I use that for testing. Works well
Old Jun 19, 2003 | 11:58 AM
TypeR 599's Avatar
Default Re: (Xsi)
the radio doesn't have wires coming out of it. it has 3 female plugs.. thanks so far guys
Old Jun 19, 2003 | 01:54 PM
vteg's Avatar
New User
Default Re: (TypeR 599)
You need the harness for that radio then.
Old Jun 19, 2003 | 05:02 PM
Xsi's Avatar
Xsi
If you're handy with a soldering iron you can solder wires straight onto the pins in the back. I've done this to several radios
Old Jun 20, 2003 | 11:55 PM
TypeR 599's Avatar
Default Re: (Xsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xsi &raquo;</TD></TR><TR><TD CLASS="quote">If you're handy with a soldering iron you can solder wires straight onto the pins in the back. I've done this to several radios</TD></TR></TABLE>
once i solder the wires onto it, what do i put on the other ends of all the wires?
Old Jun 21, 2003 | 04:37 AM
Xsi's Avatar
Xsi
I usually solder these straight onto the speaker, power ground wires etc in the car.
If you know which wire goes where it's a great help, otherwise you have an hour or so with a test light and a multimeter ahead of you
Old Jun 25, 2003 | 03:22 PM
TypeR 599's Avatar
Default Re: (Xsi)
ok thanks for everything
hondaboyqj
Feb 5, 2019 06:28 PM
SF_Dee
50
Feb 16, 2010 04:32 AM
Mr.Death
Jul 7, 2007 11:51 AM
DAYUIZ
Audio / Security / Video
10
Apr 17, 2004 07:04 PM
itsJDMyo
Nov 24, 2003 01:02 PM
