Techsoft?
Old Dec 15, 2005 | 06:50 PM
b16 matt's Avatar
Default Techsoft?
Does anyone have the techsoft wiring diagram for a dei remote start for the 00 Honda Civic EX?
Old Dec 15, 2005 | 06:55 PM
b16 matt's Avatar
Default Re: Techsoft? (b16 matt)
bumpski
Old Dec 16, 2005 | 06:57 AM
B18C_EJ8's Avatar
Paypal me a dollar and I'll get it for you.
Old Dec 16, 2005 | 08:37 AM
MLD211's Avatar
DIRECTWIRE™ WIRING INFORMATION - HONDA / CIVIC / 2000 / Remote Start
12volts white + ignition harness
Starter black/white + ignition harness or
Notes: In 6 pin white plug behind fuse box
Ignition black/yellow + ignition harness
Second Ignition yellow + ignition harness
Accessory white/black + ignition harness
Power Lock green/white - keyless entry module
Notes: The keyless entry module is white in color, and located in the drivers kick panel.
Power Unlock green/orange - keyless entry module
Lock Motor white/red drivers kick panel
Unlock Motor blue/red drivers kick panel
Parking Lights+ red/black keyless entry module
Door Trigger lt. green/red - OEM alarm plug
Notes: The OEM alarm plug is to the right side of the steering column. The plug is green.
Dome Supervision same as doors
Trunk/Hatch Pin blue/black - OEM alarm plug
Tachometer blue test connector
Notes: Drivers side fire wall under hood in a 2 pin plug
Brake Wire green/white + brake switch
Horn Trigger gray - OEM alarm plug
This wiring information is being provided free of charge on an "as is" basis, without any representation or warranty. It is your responsibility to verify any circuit before interfacing with it using a digital multimeter.
Directed electronics, Inc. assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
Old Dec 16, 2005 | 08:43 AM
B18C_EJ8's Avatar
Now you have to PayPal him a dollar.
Old Dec 16, 2005 | 09:26 AM
fcm's Avatar
fcm
Old Fart
Default Re: (B18C_EJ8)
That $1.25 is mine http://www.bulldogsecurity.com/ 94
Old Dec 19, 2005 | 05:13 AM
b16 matt's Avatar
Default Re: (fcm)
Thanks awsome.
TwoFaced
Dec 16, 2010 05:34 PM
slikz714
Jul 21, 2007 03:27 PM
choppin_civic
Jun 10, 2006 10:50 PM
JR_Si
Audio / Security / Video
Apr 18, 2003 09:39 PM
yoshi234
Feb 12, 2003 08:29 AM
