system setup, good?
Old Jul 12, 2007 | 11:46 AM
  #26
fcm's Avatar
fcm
Old Fart
Default Re: (jewpont)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jewpont &raquo;</TD></TR><TR><TD CLASS="quote">you guys do no im going for sound quality, not loudness. right now u can barely hear the sub outside the car and inside it is ridiculous. </TD></TR></TABLE>
All the more reason to run the right amount of power to the sub.
Clipping/distortion does not = sound quality, and as it is a lot easier to clip an under-powered system then it is to clip an over-powered system you will continue to get advice to up the wattage of your system.
Again, it is not the under-powered amp that does any harm to a speaker, it is driving that amp into constant clipping that hurts the speaker, [burnt VCs] and effects SQ.
I for one, am not suggesting that you double your wattage for SPL reasons, as it will only get you another 3dB anyway, I recommend it specifically for SQ and to protect the speaker 94
Old Jul 12, 2007 | 12:32 PM
  #27
jewpont's Avatar
u guys are saying that i will for sure clip the amp, but i dont see how if i dont turn it up all the way. i could understand that if i was blasting it constantly, i could clip the amp, but i dont blast it.so itll be fine
Old Jul 12, 2007 | 02:33 PM
  #28
EBP_SI's Avatar
1. if you're going to SQ why would you get an L7 in the first place??
2. dont ask for opinions on your system if you're going to tell everyone their advice doesnt matter.
3. you need a bigger amp
Old Jul 12, 2007 | 04:55 PM
  #29
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jewpont &raquo;</TD></TR><TR><TD CLASS="quote">u guys are saying that i will for sure clip the amp, but i dont see how if i dont turn it up all the way. i could understand that if i was blasting it constantly, i could clip the amp, but i dont blast it.so itll be fine</TD></TR></TABLE> Your not reading what I said, I did not say you do or will clip the amp, I also said that under-powering the sub can't hurt the sub, what I said was " and as it is a lot easier to clip an under-powered system then it is to clip an over-powered system".
I have to agree with EBP_SI, if you don't want our opinions, you shouldn't have asked, but you did and pretty much all of us told you the same thing, if you chose to ignore that, that's up to you.
You are correct, as long as you do not over-drive the amp, you will not hurt the sub, but you will also not get the performance the sub is capable of if it is under-powered.
I have been doing this a very long time and I can probably count, on one hand, the under-powered systems that did not eventually damage the speaker(s), my system being one of them, so if you can get away with it, you can join a very exclusive club 94
Old Jul 16, 2007 | 05:26 PM
  #30
chriskona's Avatar
Default Re: (fcm)
i have a single l5, love it sounds great only pushing 2 channels off a spl 990 x4
Old Jul 16, 2007 | 05:45 PM
  #31
fcm's Avatar
fcm
Old Fart
Default Re: (chriskona)
spl 990 x4 ??? 94
Fo-Do Fanatic
Audio / Security / Video
15
Feb 24, 2009 12:55 PM
BKKloppenborg
10
Jun 18, 2007 04:41 PM
redGSRguy
Jan 15, 2002 04:58 PM
RevedOut
Apr 19, 2001 10:07 PM
