subwoofer and amp compatability?
Old Aug 16, 2006 | 01:45 AM
nocturnal EG's Avatar
Default subwoofer and amp compatability?
ok so i have a jl 500/1 amp and 2 Rockford Fosgate 10" HX2's laying around. I'm not an expert or anything, but i know that the jl puts out 500watts.
the subs are DVC, 500rms and 1000max.
i am planing to only use 1 of my subs since its a better match. my question is, how should i wire the subs? i never understood how to change impedance of subs and that sort of stuff. will 1 of these HX2's work good with my 500/1?
or should i look for another amp/sub combo? i'd really like to keep the amp/subs i have now because i dont have any money...so any suggestions on wiring would be great! thanks in advance
EDIT: any diagrams or pictures of wiring would be great also!
Modified by nocturnal EG at 10:31 PM 8/16/2006
Old Aug 16, 2006 | 03:08 AM
shyboy817's Avatar
Is the subwoofer a dvc4 or dvc2? The JL 500/1 puts out 500watts rms x 1 @ 1.5-4.0ohms. So you would want to wire the subwoofer into either 2 or 4ohms, depending what your subwoofer specs are.
Old Aug 16, 2006 | 01:38 PM
Default Re: (shyboy817)
how do i know if its a dvc4 or dvc2?
it has + and - connectors on each side of the sub. i dunno if that helps?
EDIT: the subs are 4ohms x 2. (thats what it says in the manual)
Old Aug 16, 2006 | 01:39 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: (nocturnal EG)
look if it says 4 ohm or 2 ohm
Old Aug 16, 2006 | 01:45 PM
Default Re: (wrx-killer-Sti eater)
i believe it is a dvc 4 ohm speaker
Old Aug 16, 2006 | 02:01 PM
wire the sub voice coil like this. Positive to positive and the negitive to negitive. This is call parallel- and will give you a 2 ohm load. here a diagram
http://www.rockfordfosgate.com...s+x+2
You should be on your way now
Old Aug 16, 2006 | 02:19 PM
cool thanks bro
now can you explain to me what parallel and series means? you said parallel is +and+, -and-...so how would wiring subs in a series be like?
Old Aug 16, 2006 | 02:47 PM
darkspector2.0's Avatar
amp + to spk1 +
sp1 - to spk 2 +
spk2 - to amp -
Old Aug 16, 2006 | 02:50 PM
http://www.bcae1.com/srsparll.htm
Old Aug 17, 2006 | 05:03 AM
slowSOHCvtec's Avatar
Default Re: (darkspector2.0)
that site isnt really all that accurate,
Total resistance of parallel resistors = resistance of a single component/number of resistors
Total resistance of parallel resistors = 1000/2
Total resistance of parallel resistors = 500 ohms
that is totally wrong here is a better site for ur understanding
http://www.termpro.com/articles/spkrz.html
Old Aug 18, 2006 | 02:18 PM
Default Re: (slowSOHCvtec)
thanks for all the input! links helped a lot!
Matthew_zero
Audio / Security / Video
Mar 7, 2008 11:07 AM
Chi
Mar 7, 2007 10:09 AM
Mazzazx51
May 19, 2004 05:55 AM
GroundZer0 336
20
Aug 30, 2003 04:27 AM
vtec-outlaw
Feb 4, 2002 12:45 PM
