Subs in the winter
Old Nov 11, 2003 | 07:06 PM
Atheist's Avatar
Default Subs in the winter
I've been hearing that subs tend to crack in the cold winter, is this true? Should I take mine out?
Old Nov 11, 2003 | 07:25 PM
brads94accord's Avatar
the only thing i have heard to do is just cover them up with a blanket or towel and then take it off when you start driving the car and just leave the volume down for a little bit and gradually crank it up. that will warm it up
Old Nov 12, 2003 | 12:18 PM
Thirty-Nine's Avatar
Default Re: (brads94accord)
I've lived in Minnesota and Wisconsin all my life and haven't had a problem.
Old Nov 12, 2003 | 12:56 PM
t0p_sh0tta's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brads94accord &raquo;</TD></TR><TR><TD CLASS="quote">the only thing i have heard to do is just cover them up with a blanket or towel</TD></TR></TABLE>
What good will that do? The speaker gives off no heat when it's not in use. A blanket traps heat FYI, it doesn't generate it. Cold is good, it keeps everything running cool. Will the speaker's construction materials get more brittle as the temp drops? Yes, but not enough to warrant any change in listening habits. IMO.
Old Nov 12, 2003 | 01:23 PM
4uhataz's Avatar
Default Re: (t0p_sh0tta)
Usually playing the subs at a low volume for about 3 mintues or so will begin to warm them up enough. What usually happens is the suspension gets stiff in extremely cold weather and it's just like a car, gotta warm it up.
Old Nov 12, 2003 | 01:41 PM
Stew Pidasso's Avatar
Default Re: (4uhataz)
You should allow some time for them to warm up. Just don't crank it first thing in sub zero weather. Another thing is if the voicecoils are filled with ferrofluid. If they are, they shouldn't be driven hard until the speaker warms up a bit. It's like the oil in your car when it's cold.
Old Nov 13, 2003 | 03:44 AM
Atheist's Avatar
Ok so bottom line is that if I turn 'em up slow, I'll be fine? Sounds good, thanks!
Old Nov 15, 2003 | 04:50 PM
Bbasso's Avatar
I never heard any of that BS before, I have had systems as long as I can remember and never, not once had a problem due to cold.
Crank up the volume.
square_1
Feb 1, 2008 06:12 PM
mr poo
Audio / Security / Video
14
Mar 15, 2007 10:31 PM
bassisliffe
Aug 30, 2004 05:22 PM
RaYnE
Nov 24, 2003 06:40 PM
RiceRacist
10
Oct 26, 2003 04:00 PM
