Sub wont work everytime
Old Mar 19, 2008 | 07:31 AM
stevethecat's Avatar
Default Sub wont work everytime
K so a JL audio sub and amp came hooked up to my car. But to access another amp in the trunk a removed the sub and box from the trunk. The only wires i disconnected were the two going into the sub box from the amp. When reinstalled the sub would work but would be so faint you had to hold your ear to the box. then one day is worked fine, about a week later is did it again. Now i can never tell if it will play... Help
Old Mar 19, 2008 | 07:35 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Sub wont work everytime (stevethecat)
Sounds like the sub is blown to me, but I could be incorrect. Check your wiring if you know what your doing. As a test, play the music at normal volume, and push in on the sub and see if it plays. If it does, your sub is blown.
Old Mar 19, 2008 | 07:38 AM
Default Re: Sub wont work everytime (JDM_Ej)
when it plays it hits hard like normal, but if i crank it i hear a pop and the it doesnt work till i turn it down
Old Mar 19, 2008 | 07:43 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stevethecat &raquo;</TD></TR><TR><TD CLASS="quote">when it plays it hits hard like normal, but if i crank it i hear a pop and the it doesnt work till i turn it down</TD></TR></TABLE>
If thats the case, your amp may be going into protection.
Old Mar 19, 2008 | 07:45 AM
Protection?
Old Mar 19, 2008 | 02:24 PM
94_DC4's Avatar
Your amp is going into protection mode for a reason. Check and make sure the wiring for the sub is secure.
Old Mar 19, 2008 | 05:32 PM
Acidcrakker's Avatar
Default Re: Sub wont work everytime (94_DC4)
Mabey try and turn down the Gain on your Amplifier see if that does anything.
Old Mar 20, 2008 | 07:37 PM
Default Re: Sub wont work everytime (Acidcrakker)
gain?
Old Mar 21, 2008 | 07:40 AM
Well what do you know about amps and how they work?
Protection is turned on for the Amps protection, IE bad circut somewhere, overload,
Gain is the level of power that your amp puts out.
Its possible that your gain is turned all the way up, and when it hits high it generates too much power and instead of shorting itself out, it goes into protection more. I doubt it though
Old Mar 24, 2008 | 11:31 PM
~steph~'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94_DC4 &raquo;</TD></TR><TR><TD CLASS="quote">Your amp is going into protection mode for a reason. Check and make sure the wiring for the sub is secure. </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stevethecat &raquo;</TD></TR><TR><TD CLASS="quote">gain?</TD></TR></TABLE>possibly
Old Mar 26, 2008 | 10:55 AM
JayDeeEmm's Avatar
could be the amp or a burnt coil
pjr710
Audio / Security / Video
21
Aug 6, 2008 02:48 PM
dth0ng69
Jul 9, 2008 04:29 PM
oilguzzler
Jul 24, 2006 09:18 AM
95blk2draccordEXMT
Jul 5, 2004 06:02 PM
cvclover
10
May 26, 2004 09:04 AM
