combining amps....
Old Jul 23, 2006 | 10:55 AM
oilguzzler's Avatar
Default combining amps....
hey i need some help, i have two amps, a ppi d500/1 mono block and a old old school dei 2102, 400rms 2 channel. is there any way remotly possible that i can have both these amps running my 2 ppi pc122(500max, dual 2ohm voice coil) subs? they are in a dual vented box as well. thanks for the help.
Old Jul 23, 2006 | 11:26 AM
fcm's Avatar
fcm
Old Fart
Default Re: combining amps.... (oilguzzler)
NO, the amps are not "strapable", the only way would be to drive each sub off one of the amps, NOT recommended, [hard to do even if the amps are identical, unless using separate boxes or a 2 chambered box]. 94
Old Jul 23, 2006 | 07:15 PM
oilguzzler's Avatar
Default Re: combining amps.... (fcm)
so say i sealed my box off into two seperate boxes(sealed the divider in the middle), would that work? or would it sound like crap?
Old Jul 24, 2006 | 06:11 AM
fcm's Avatar
fcm
Old Fart
Yes you could, [and would have to] the trick then would be to balance the outputs, [gains] of both amps so the subs would "work" at the same level, and as I said that can be hard with identical amps, [unless strapable].
Can't hurt to try, if it does not work you can always get another amp to do the job, the sub box will not change. 94
Old Jul 24, 2006 | 09:18 AM
nsxxtreme's Avatar
I believe you could "strap" these two amps, it wouldn't be an easy task. You would need an oscilliscope to verify the outputs are the same.
Not something I would recommend. But it "could" be done.
*edit* oops didn't see the second amp was a 2 channel. Nope cant be done easily would need a transformer. More work then its worth.
kelviiv
Audio / Security / Video
Dec 27, 2009 05:38 PM
Hanmin
Jun 3, 2009 10:36 PM
cvclover
10
May 26, 2004 09:04 AM
Bud
Feb 29, 2004 06:49 PM
4doorex
Oct 24, 2003 10:57 PM
