Sub Uninstall?
Old Apr 16, 2007 | 10:22 AM
pgFA's Avatar
Default Sub Uninstall?
I getting a little tired of load bass so I want to take out my subs for a while. Main question, is it ok just to remove the subs and the fuse close to the batt and leave the amp and all the wiring there or do I have to uninstall everything? TIA
Old Apr 16, 2007 | 10:46 AM
B18C_EJ8's Avatar
Yes, You can leave the wiring.
Remove the fuse from the battery wire under the hood & cap off the remote wire (usually blue).
Old Apr 16, 2007 | 11:12 AM
pgFA's Avatar
Default Re: (B18C_EJ8)
What do you mean cap off?
Old Apr 16, 2007 | 11:50 AM
B18C_EJ8's Avatar
Cap off or otherwise insulate against shorts to ground...
Old Apr 18, 2007 | 07:35 AM
pgFA's Avatar
Is it really necessary to remove the remote wire?
Old Apr 18, 2007 | 07:38 AM
B18C_EJ8's Avatar
WTF are you talking about?
I didn't say remove the wire.
I said cap it off.
Old Apr 19, 2007 | 09:48 AM
pgFA's Avatar
How would I insulate it if Im not gonna remove it?
Old Apr 19, 2007 | 09:54 AM
B18C_EJ8's Avatar
Holy crap...
Wrap the end that you disconnect from the amp with tape. Or use a crimp cap.
Old Apr 24, 2007 | 12:17 AM
SCIVIC94's Avatar
he said he was leaving the amp in.he is only removing the sub enclosure.why cap a wire that is still connected?
stackz
Audio / Security / Video
Mar 5, 2007 12:21 PM
R Thizzel
17
Nov 22, 2004 05:48 PM
tub_sephiroth
Mar 27, 2004 09:07 AM
GSR-REX
11
Jan 24, 2003 07:14 AM
acuracer
Jan 2, 2002 09:39 PM
