Sub Troubles
Old Oct 21, 2003 | 03:51 PM
Arbadacarba's Avatar
Default Sub Troubles
I recently picked up a Sony amp... I know many of you guys don't like Sony, but for the price I paid, and compared to what I had before (nothing) I'm happy to settle...
When I first Installed it it worked Great... Very Happy... I ran 4 guage wires from the battery back to a box in the back where the amp can be plugged into the car and removed very easily.
After a few weeks I noticed it cutting out and coming back every now and then... Eventually it stopped coming back on altogether. No lights and no power.
I tested it and discovered that my ground, which had been fine had failed. I re grounded it and it came back to life... But it's still cutting out regularly...
I have it grounded on one of the bolts that holds the brake lights in place...
Is this a common issue for these subs or am I just not getting a good ground? How would I go about Testing this?
Old Oct 21, 2003 | 04:03 PM
PetroGuyX's Avatar
most of the time grounding stuff to bolts isn't good, make your own ground... put a ring terminal on the ground wire and use a self tap in screw and find a better ground, also is your amp set too high? does it go into protection? that could be why it cuts on and off
Old Oct 21, 2003 | 04:04 PM
Al Bundy's Avatar
Default Re: Sub Troubles (Arbadacarba)
The place where you grounded, did u sand off the car paint? If you sand it off, it will have a better connection.
Old Oct 21, 2003 | 04:07 PM
Ludeboi's Avatar
Default Re: Sub Troubles (Al Bundy)
ditto, sand it down to where u see bare metal! also, did you wire your subs correctly?
bug b16b
Acura TSX
Mar 19, 2012 08:43 PM
froogle29
Audio / Security / Video
Oct 29, 2009 07:44 PM
biotech0123
Oct 10, 2008 08:12 PM
notguilty411
10
Oct 18, 2005 09:58 AM
kevinoneill
21
Feb 29, 2004 09:58 PM
