sub cutting out
Old Jun 13, 2006 | 05:05 PM
thats fresh's Avatar
Default sub cutting out
okay i've just purchashed a new system. 2 pioneer 12s and a pioneer premier 800watt mono amp. i hav a pioneer premier HU and speakers. pretty much a full pinoeer system. my question is..my subs seem to cut out at half volume, which is 30. ( max is 62) it will play for a short time at higher volumes, i like to listen around 32-38ish. the bass will hit and then not and so on. then i will hav to bring the volume around 28-30 to hav the bass bump smoothly again. i think that the subs arent gettin enough voltage at higher volumes. i was thinking about gettin a Cap. or even a Otpima yellow top battery to fix this problem. but i need some advice from u guys. so0o preach away
Old Jun 13, 2006 | 05:09 PM
94_DC4's Avatar
Default Re: sub cutting out (thats fresh)
What ohms are your subs and Amp? It could be a problem with impeadences not matching up and the amp going into protect mode.
Old Jun 13, 2006 | 07:51 PM
Default Re: sub cutting out (SiRGDC)
amp is 4 ohm 500w but bridge which i am is 2 ohm 800w. the subs are 4ohm 800W
Old Jun 13, 2006 | 07:52 PM
yea i'm not sure what impeadance is......i here it often brought up in audio forums, but if that's the case..help a brotha out!
Old Jun 13, 2006 | 09:10 PM
imadigitalgod's Avatar
what is the model # of ur subs and amp? it seems like it is goin into protection mode like SiRGDC said
do you have the grounds and power cables securly anchored? i just fixed someones system this weekend that they did have the ground points bolted down, they just didnt bother to crimp the cables to the wire...u could just easily bump the wire and it would fall out
His complaint was when the subs were turned up the amp would cutout also, but when turned down it woudl turn back on, it was probably making the ground cable shake and temp. come off of the ground point
Old Jun 14, 2006 | 01:32 AM
Skip01's Avatar
Default Re: sub cutting out (imadigitalgod)
Whats your gain set at?
Seems like its clipping.
Good Luck.
Old Jun 14, 2006 | 02:42 PM
subs are 12 inch pioneer TS-301R
12" 4-ohm subwoofer
composite IMPP cone with wide roll urethane surround
power range: 50-150 RMS watts (800 watts peak power)
frequency response: 20-4000 Hz
sensitivity: 91 dB
mounting depth: 5-3/4"
sealed box volume: 1.00-2.00 cu. ft.
ported box volume: 1.25-2.05 cu. ft.
Recommended Q-Logic Box Type: 1, 2, 3, 4
warranty: 1 year
AMP is GM7150M
Pioneer Premier GM-7150M Mono Channel Amplifier
Peak Music Power: 800 Watts
Number of Channels: 1
Load Impedance Capability: 2~8 Ohm
Continuous Power (4 ohm): 250W x 1
Continuous Power (2 ohm): 360W x 1
Frequency Response: 10Hz ~ 240Hz
Total Harmonic Distortion: 0.008%
Signal-to-Noise Ratio: 100dB
Dimensions: 12" x 2-3/8" x 12-3/4"
Features:
PWM Regulated MOSFET Power Supply
Screw-Type Speaker Terminals
Balanced Isolator Input Circuit
RCA Inputs Gold, 2 Channel
Speaker Level Input 2 Channel
Input Level Control Hi-Volt (200mV ~ 6.5v)
Built-in Crossover Selectable LPF
Bass Level Control 50Hz, 0/6/9/12dB
Pioneer 2-Year Warranty
imadigitalgod
Audio / Security / Video
18
May 13, 2008 04:00 PM
mmajedi
Nov 5, 2007 08:45 AM
gunnerman
20
Oct 9, 2007 08:39 AM
blindO
May 30, 2005 07:21 AM
pr0jektdc2
Nov 11, 2002 09:54 PM
