sub cutting out
Old Feb 1, 2006 | 07:34 AM
DA jeshy's Avatar
Default sub cutting out
i have a 93 integra and at high rpms my subs cut out. i have no idea whats going on because at the next stop light it comes back. anyone know whats going on?
Old Feb 1, 2006 | 07:55 AM
sleeperteg's Avatar
Default Re: sub cutting out (jeshy)
check amps n see if they are losin power at all when they cut out.
Old Feb 1, 2006 | 08:51 AM
DA jeshy's Avatar
Default Re: sub cutting out (sleeperteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeperteg &raquo;</TD></TR><TR><TD CLASS="quote">check amps n see if they are losin power at all when they cut out.</TD></TR></TABLE>
Amp turns off when subs cut out.
Old Feb 1, 2006 | 09:14 AM
sleeperteg's Avatar
either somethin isnt connected right and the amp is losing power cuz i had that problem. it turned out i just had to re-fasten the power cables to the battery and its been fine since. i say start by tracing your wiring and makin sure everythin is solid. if that doesnt fix it for you then it could be something with the amp. maybe gettin to hot and clippin out or going into protection mode. check it out n get back. GL
Old Feb 1, 2006 | 03:06 PM
mattbishop's Avatar
Its your ground wire, 99% positive
Old Feb 1, 2006 | 03:27 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeshy &raquo;</TD></TR><TR><TD CLASS="quote">i have a 93 integra and at high rpms my subs cut out. i have no idea whats going on because at the next stop light it comes back. anyone know whats going on?</TD></TR></TABLE> As mentioned above check your wiring, try this also.....
disconnect the amps turn on lead, [tape it off so it can't short out] with a short piece of wire make a jumper from the amps pos. (+) term to the "turn on terminal" screw in place, amp will turn on even if car is off, make sure volume is down and HU is off until you start the car, once car is running turn on the HU, [you may hear a "thump", don't worry it can't hurt] drive the car and see if amp still cuts out.......
If yes, problem is not in the amp control wiring or HU.
If no, then there is a problem in the HU or it's power and ground wiring or the amp control lead running to the amp from the HU. 94
lsracer27
Audio / Security / Video
Jun 14, 2006 01:42 AM
hookedonvtec
Feb 6, 2005 03:08 PM
Red_EM1
May 10, 2004 06:53 PM
Ziggie
Aug 22, 2003 03:23 PM
The Poopsmith
10
Jun 10, 2003 10:17 AM
