sub/amp wiring question
Is there a way to wire my subs(2-4ohmSVC) into a 4 ohm load??.........Whats the best way to wire my subs to get the most power to them?...(note:low pass signal is mono)
Amp - HiFonics Zeus ZX4000
100w x 2 RMS @ 4ohm
200w x 2 RMS @ 2ohm
400w x 1 RMS @ 4ohm
Subs - Two 12 inch "Gr-Gravity" (Sealed Enclosure)
500watt MAX each
SVC
??RMS??
Thank You For any Help,
CF04
Looks like your only option is to wire them on seperate channels.
If the amp won't handle 2 Ohm mono, then you have to do it that way.
Your only other option would be wiring the subs in series and raising the Ohm load to 8Ohms...which would leave you at ~200WRMS in a single channel.
So you're stuck to 100W per sub, and doing seperate channels at 4Ohm is your best option.
http://www.lightningaudio.com/....y=10
hope this helps u some
suspendedHatch
Audio / Security / Video
10
Mar 25, 2007 08:26 AM
my95teg
Jan 18, 2007 02:25 PM
