wiring subs
Old Apr 19, 2003 | 04:57 PM
Liquidgsr's Avatar
Default wiring subs
I have 2 subs that have a DVC and are 2 ohms each. Now my amp is 4 ohms. I was wondering how i can wire this up.
Old Apr 19, 2003 | 05:03 PM
t0p_sh0tta's Avatar
Default Re: wiring subs (Liquidgsr)
You can't get a 4 ohm load with those subs. What amp are you using?
Old Apr 19, 2003 | 05:12 PM
Liquidgsr's Avatar
Default Re: wiring subs (t0p_sh0tta)
i have a MTX 2180 amp....will it work if just use the amp and run the subs parrallel then in a series? I mean like can i
Old Apr 19, 2003 | 05:22 PM
t0p_sh0tta's Avatar
You can wire it at 2 ohms or .5 ohms. Is that amp 2 ohm stable?
You can wire it at 4 ohms but it isn't recommended. You would have to short out one of the voice coils on each driver. By doing this you would basically be powering 1 of the coils in each, and decrease power handling by half. DO NOT just wire one of the coils. The other must be shorted out with resistors.
Old Apr 19, 2003 | 09:13 PM
Liquidgsr's Avatar
am is not 2 ohm stable it is 4 ohm stable i believe....would shorting it out with resisters damage the sub itself.
Old Apr 20, 2003 | 05:46 AM
rjr162's Avatar
I know the MTX mono amps which are rated or 2 ohms handle 1 ohm fine... don't know about the 2 channel though. Don't use resistors, that would be pointless or cause the resistors to burn up. Might just want to go grab a nice little mono amp to run your setup, almost all are 2 ohm stable
Feli
Audio / Security / Video
10
Dec 13, 2010 07:57 PM
my95teg
Jan 18, 2007 02:25 PM
ChronicFrogs2004
May 5, 2005 08:49 PM
brickonwheels
Jan 12, 2004 09:33 PM
ichibano
Mar 23, 2003 04:07 PM
