sub/amp compatibility
Old Dec 20, 2005 | 05:18 AM
PnoyJeff's Avatar
Default sub/amp compatibility
I have one AUDIOBAHN AWIS10P SUBWOOFER
http://www.cardomain.com/item/ABNAWIS10P
http://www.caraudiodeals.com/p...d=201
I am thinking of ordering a POWER ACOUSTIK POWER A3000DB
http://www.cardomain.com/item/POWA3000DB
http://www.etronics.com/produc...000db
I am going to order it ASAP if it can...if not..ill be sad
Old Dec 20, 2005 | 09:44 AM
silentblackhat's Avatar
Default Re: sub/amp compatibility (PnoyJeff)
If I were you, i havnt looked at all the reviews or anything but with the specs of your subwoofer(its the quad voice coil one isnt it?) I would get the PowerAcoustik Class D Series #A2400DB mono block amp. The one you have listed wouldo verpower the subwoofer by 300 watts rms and might damage it after a bit. In my opinion the PowerAcoustik Class D Series #A2400DB would be a better match. Remember to wire it so it puts a 2 ohm load with that amp I provided.
Old Dec 20, 2005 | 09:47 AM
Default Re: sub/amp compatibility (silentblackhat)
i forgot to also say that the amp I provided would only underpower the sub by 100 watts but your amp would over power it by 300. the sub can hold 1500 all together and your amp puts out 1800rms and the one i showed putsout 1400. with the amp i provided its a safer bet.
Old Dec 20, 2005 | 07:37 PM
PnoyJeff's Avatar
thanks for the help..ill look into the other amp.
Old Dec 20, 2005 | 08:14 PM
PnoyJeff's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silentblackhat &raquo;</TD></TR><TR><TD CLASS="quote">i forgot to also say that the amp I provided would only underpower the sub by 100 watts but your amp would over power it by 300. the sub can hold 1500 all together and your amp puts out 1800rms and the one i showed putsout 1400. with the amp i provided its a safer bet. </TD></TR></TABLE>
but the sites i been looking at claim 3000watts..not any higher.
but ill go with what u said..but isnt the actual power of tha amp a lower by around 100-400watts to the rated power anyway??
u probably know more bout this stuff than me but i just tyhought id ask
Old Dec 21, 2005 | 01:11 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PnoyJeff &raquo;</TD></TR><TR><TD CLASS="quote">I have one AUDIOBAHN AWIS10P SUBWOOFER
I am going to order it ASAP if it can...if not..ill be sad</TD></TR></TABLE> It is a good match, a 1500W rms sub with a 1800W rms into a 2 ohm load, a little more power is a lot better then a little less power.
Believe me I have replaced more blown speakers on "underpowered" systems then I have on "overpowered systems, [100s of x more] 94
Old Dec 21, 2005 | 01:14 PM
fcm's Avatar
fcm
Old Fart
Default Re: sub/amp compatibility (fcm)
One more thing, you are going to need one hell of a sub box for that setup, no off the shelf sub box that I know of is going to work. 94
Old Dec 21, 2005 | 07:41 PM
PnoyJeff's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">One more thing, you are going to need one hell of a sub box for that setup, no off the shelf sub box that I know of is going to work. 94</TD></TR></TABLE>
yeh..im getting one custom built probably this week or next week.
do u think 1'' mdf would be good enough for this setup?
Old Dec 22, 2005 | 02:36 PM
fcm's Avatar
fcm
Old Fart
Yes I would use 1" MDF I would also brace every seam, "paint" the inside of box and the cut edges, [including the speaker hole and speaker term. hole] with fiberglass resin to seal it up, I would also use "T" nuts and blots to mount the sub instead of screws, or make the baffle 2" thick and use 2" number 10 screws. 94
Old Dec 22, 2005 | 07:46 PM
PnoyJeff's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">Yes I would use 1" MDF I would also brace every seam, "paint" the inside of box and the cut edges, [including the speaker hole and speaker term. hole] with fiberglass resin to seal it up, I would also use "T" nuts and blots to mount the sub instead of screws, or make the baffle 2" thick and use 2" number 10 screws. 94</TD></TR></TABLE>
hopefully the people that are building my box know as much as you...its a reputable shop that everyone goes to for their BIG audio needs..circuit city n est buy dont cut it...but i dont know their ways because this is my first setup n i just went to them the first time this week. hopefully they build good custom boxes...for freaking 175 dollars it better not break on me or else they can see their wood fly through their windows...jk im not violent
Old Dec 23, 2005 | 10:23 AM
fcm's Avatar
fcm
Old Fart
LOL..... $175 for a box for that sub, we would charge $300 and that would be the raw box, no paint or carpet, and you would have to install the sub yourself.
I would maybe just ask them how they are going to build it, just using 1" MDF is not going to cut it, although it will work and I don't think it will fall apart, but to get everything out of that amp and sub, the box will have to be "bullet proof" 94
Old Dec 23, 2005 | 04:26 PM
PnoyJeff's Avatar
ill be sure to check up on their methods before paying them anything..
any more tips to help me out with this ...my goal is to have it all in by 2 weeks..
as for wiring...how big do i need to go..im thinking im gonna need big *** monster cables...
Old Dec 23, 2005 | 06:28 PM
fcm's Avatar
fcm
Old Fart
Well at 1800W rms you are going to need 2ga power and ground cable.
Tell me what size and kind of fuse/s are in the amp? 94
Old Dec 23, 2005 | 06:55 PM
PnoyJeff's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">Well at 1800W rms you are going to need 2ga power and ground cable.
Tell me what size and kind of fuse/s are in the amp? 94</TD></TR></TABLE>
i dont know..how can i figure this out
Old Dec 23, 2005 | 07:19 PM
fcm's Avatar
fcm
Old Fart
Look on the amp and tell me what size, [in amps] the fuse is or fuses are if there is more then one. 94
Old Dec 25, 2005 | 09:48 AM
PnoyJeff's Avatar
oh ok...ill post em u when my amp comes on wednesday
Old Dec 25, 2005 | 09:54 AM
fcm's Avatar
fcm
Old Fart
OIC...... I thought you already had the amp. 94
Old Dec 30, 2005 | 11:19 AM
PnoyJeff's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">Look on the amp and tell me what size, [in amps] the fuse is or fuses are if there is more then one. 94</TD></TR></TABLE>
im not sure if im looking at the right thing....what kind of number am i looking for
Fat Cash Stack
Audio / Security / Video
22
Apr 8, 2012 09:35 PM
ReV LiMiT
Mar 12, 2006 02:41 PM
deeweezy
Jun 23, 2004 02:36 PM
bradykiller
Mar 31, 2004 06:48 PM
mstewar
Sep 10, 2003 06:54 PM
