stupid audio setup in SI..help
Old Jul 19, 2006 | 02:28 PM
kinkyintegra's Avatar
Default stupid audio setup in 99 SI..help
Okay so i bought my 99 SI and the previous owner had a headunit and then subs in the back, so whatever i took out the subs....he put the stock SI headunit in the car, just the radio/cd player, no tape part....for some reason only the right front speaker and tweeter work. I looked at the rear speakers behind the seats and they have speaker wire coming from them and not connected to anything...I want to hook up all the speakers to the stock head unit. I dont need the tape part right? the radio/cd head unit is where everything hooks up to right?
Old Jul 19, 2006 | 03:59 PM
B18C_EJ8's Avatar
Are they aftermarket speakers or factory?
And no, you don't need to have the tape player hooked up for the head unit to function.
Old Jul 19, 2006 | 07:55 PM
okay well i got the front speakers hooked up...but the rear speakers im pretty sure are aftermarket, but that shouldnt matter since they have the same plug and play things right? i looked under the rear seat and there is a plug with nothing hooked up to it, so im guessing i need a plug going from the speakers to hook up into this plug
Old Jul 19, 2006 | 08:38 PM
B18C-REXXX's Avatar
if they are aftermarket, you could just cut the plug out and hook it up to your speakers just make sure you know which cable is negative/positive.
Old Jul 19, 2006 | 08:47 PM
bpr0422's Avatar
Default Re: stupid audio setup in 99 SI..help (kinkyintegra)
don't cut the harness!!!!
use some paper clips or really stiff wire(that will fit into the harness plugs)...
solder it to ur speaker wires, and wrap em tightly in eletrical tape, except about 1/4 to a half an inch to shove into the harness..
it should work fine.. and u'll save ur harnness form being cut...
Old Jul 20, 2006 | 04:30 AM
B18C_EJ8's Avatar
Wait wait wait... What plug is this under the rear seat?? As far as I know, there are no audio plugs under the rear seat...
And yes it matters if they're aftermarket or not... And no, aftermarket speakers do not have "the same plug and play things".
Your descriptions of what is in the car are confusing... Pics would help of said speakers and wires. And plug.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">don't cut the harness!!!!
Or you could not be ghetto and spend the $5 on the speaker adapter plugs....
Old Jul 20, 2006 | 06:27 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">Wait wait wait... What plug is this under the rear seat?? As far as I know, there are no audio plugs under the rear seat...
Or you could not be ghetto and spend the $5 on the speaker adapter plugs.... </TD></TR></TABLE> Ditto the above. I also know of no speaker wire/plugs that would be under the rear seat, [unless they have been pulled out and put there.
The stock rear speaker wir colors are.....
right rear + - red/yellow
right rear - - brown/white
left rear + - blue/yellow
left rear - - gray/white
You do not have to cut anything, the adapters are the best way, plug and play, but you can also disassemble the oem speaker plug, [open it up and remove the metal terminals and they will fit the aftermarket speaker, [the neg.(-) will have to be "crimped" a little as it will be loose. 94
Old Jul 20, 2006 | 10:52 AM
Carbonciv's Avatar
Default Re: stupid audio setup in 99 SI..help (bpr0422)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bpr0422 &raquo;</TD></TR><TR><TD CLASS="quote">don't cut the harness!!!!
it should work fine.. and u'll save ur harnness form being cut...</TD></TR></TABLE>
Dude thats the worst idea I have ever heard. Dont listen to this guy. Get a speaker harness at a local stereo shop. Their like 7 bucks and let you go from stock to being able to hook up aftermarket speakers. Then you still get to keep the stock plug. Seriously dont use paper clips for anything other than keeping paper together.
Old Jul 20, 2006 | 07:02 PM
B18C-REXXX's Avatar
just cut the wires, strip and connect to your speakers. cheap, fast, ghetto and easy.
Old Jul 20, 2006 | 11:09 PM
mike686's Avatar
Default Re: stupid audio setup in 99 SI..help (Carbonciv)
lol paperclips
Old Jul 20, 2006 | 11:30 PM
bpr0422's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Carbonciv &raquo;</TD></TR><TR><TD CLASS="quote">Dude thats the worst idea I have ever heard. Dont listen to this guy. Get a speaker harness at a local stereo shop. Their like 7 bucks and let you go from stock to being able to hook up aftermarket speakers. Then you still get to keep the stock plug. Seriously dont use paper clips for anything other than keeping paper together.</TD></TR></TABLE>
psh..
a harness for 7 bucks??
when all it is is plastic, steel/aluminum/tin, and a copper wire...
what are paper clips made out of? steel/aluminum/tin...
its the same exact stuff...
cut paper clip into short lenght, solder, its good to go...
the paper clips are just for the stock harness side, on the speaker side you have to use female dissconnects..
end product with paperclips should look like this:
if u don't want to use paper clips.. u could tin the ends of the wire.. but the wire has to be pretty thin.. if ur running off of stock wiring... its okay cause ur just limited to how small of an awg u can use by the stock wiring...
Modified by bpr0422 at 12:45 AM 7/21/2006
Old Jul 21, 2006 | 04:45 AM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Or you could not be ghetto and spend the $5 on the speaker adapter plugs....
Old Jul 21, 2006 | 09:01 AM
okay so as i was saying underneath the seat, on each side underneath there is an orange plug with a blue and gray wire coming from the plug. nothing is plugged into each plug on each side. im guessing thats the speaker plugs? what else could it be....
Old Jul 21, 2006 | 10:07 AM
B18C_EJ8's Avatar
Not trying to be a dick here (well, maybe just a little), but do you even read what people post in here? 2 people (2 experienced installers) have told you that there are no audio plugs under the back seats, yet you continue asking about them.
And as I stated previously, your descriptions of what is in the car are confusing... Pics would help of said speakers and wires. And plug.
Modified by B18C_EJ8 at 11:26 AM 7/21/2006
Modified by B18C_EJ8 at 11:29 AM 7/21/2006
Old Jul 21, 2006 | 10:33 AM
fcm's Avatar
fcm
Old Fart
Default Re: (kinkyintegra)
You may be right, it may be speaker plugs, but as I said, only if someone has pulled them out, also you say there is a blue and gray wire, is that blue with a yellow stripe and gray with a white strip, [left rear speaker]? Also is it a blue and gray on both sides?
If so, you have the only 99SI with the speaker plugs under the seat with the same color, [solid] wires on both sides I have ever seen or heard about
Can you take a pix and show us the plugs and wires?
None of us here are trying to give you a hard time, but what you are explaining has never come up in any 99SI I have done, and if the colors are solid and the same on both sides I have not seen that on any Honda/Acura and I have been a car audio installer for a long time. 94
Old Jul 21, 2006 | 10:39 AM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">You may be right, it may be speaker plugs, but as I said, only if someone has pulled them out,</TD></TR></TABLE>
I don't think I remember speaker connectors being orange...
Old Jul 21, 2006 | 12:18 PM
no i understand everything...i will take pictures today of them, but maybe he put new plugs on the wires on the speakers? idk thats why i was asking if the orange plugs might be audio or if not, what are they? you have all been helpful so far and ill get back to you with better descriptions and pictures later.
Old Jul 21, 2006 | 01:21 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
I know yellow plugs are srs system. But orange is abs system right?! And it located in the rear side of the back seat passanger. Pics would deff help. most of all honda speakers plugs are gray
Old Jul 21, 2006 | 07:43 PM
8520's Avatar
]</TD></TR></TABLE>
Ghetto as hell
jardolei
Mar 8, 2007 12:34 PM
B18EG6
Audio / Security / Video
Jun 6, 2006 09:59 AM
14
Oct 28, 2005 01:45 PM
dylokjai
Mar 22, 2005 02:01 PM
CivicSiRracer69
Oct 18, 2003 07:32 AM
