--Strange Problem--Please Help
Old Apr 21, 2005 | 01:03 PM
Arsenal's Avatar
Default --Strange Problem--Please Help
Just got a new deck, JVC with an AUX input so could play my ipod on it, well had it for a few days no problems, then today started going intermtittent on and off, then just shut off completely.
So took it out, put the old Kenwood deck in, and its as if power is going to it, but won't show up the display, the reason I know this is that it ejected a CD which I left in.
The same thing happens with the JVC unit. As if it won't stay on. It is the same in all ignition positions.
Any ideas, BTW, there is no cutting and splicing, I just buy the 2 wire harnesses that connect together.
Old Apr 21, 2005 | 03:56 PM
parasonic's Avatar
Default Re: --Strange Problem--Please Help (Arsenal)
Check your fuses. It sounds more like a connection problem to me as if something's loose, but it seems that your "memory wire" is giving power while your main power wire isn't.
Old Apr 21, 2005 | 04:07 PM
Arsenal's Avatar
Default Re: --Strange Problem--Please Help (parasonic)
I checked all the connections and everything seems fine, really not sure how to check the memory wire.
Old Apr 21, 2005 | 04:14 PM
parasonic's Avatar
The memory wire seems to be what is working. Put a voltmeter on the main power wire...check out the voltage before and after you turn the key to Acc II.
Old Apr 21, 2005 | 04:26 PM
Arsenal's Avatar
Do you happen to know which pin it is?
Old Apr 21, 2005 | 06:07 PM
parasonic's Avatar
No.
Old Apr 22, 2005 | 08:30 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arsenal &raquo;</TD></TR><TR><TD CLASS="quote">Do you happen to know which pin it is?</TD></TR></TABLE> On the aftermarket HUs the acc. power wire is red, [fused at the incar fusebox] and the constant, [memory] is yellow, [fused at the engine bay fusebox] fuse locations in Honda/Acura. 94
Old Apr 24, 2005 | 07:41 AM
Arsenal's Avatar
Default Re: --Strange Problem--Please Help (fcm)
Thanks, Will take a look now!
smartguysjt
Dec 17, 2010 08:06 AM
laelowimports
Mar 6, 2008 01:27 PM
JdM_RACeR07
Aug 29, 2006 10:11 PM
MarkV1184
Audio / Security / Video
Jun 24, 2005 10:32 AM
9five1five
Feb 23, 2002 04:41 PM
