Strange issues with Sony head unit.
Old Nov 16, 2006 | 01:07 PM
dem0nk1d's Avatar
Default Strange issues with Sony head unit.
Well the unit works fine, plays Cd's etc does what it's suppose to do. The driver side speaker works fine. The passenger side doesn't. I've test continuity from the head units harness to the door speaker location and it shows to be ok... I've hooked the speakers directly up to the main Sony harness, because i just quick disconnect clips in-case i ever need to upgrade. The speaker works fine.. what do you think is going on?
Old Nov 16, 2006 | 03:36 PM
B18C_EJ8's Avatar
Is the speaker grounding out when it's installed?? If so, that'll cause it not to function...
Old Nov 16, 2006 | 04:17 PM
fcm's Avatar
fcm
Old Fart
Default Re: Strange issues with Sony head unit. (dem0nk1d)
OK.... so I understand, the passengers speaker does not work and if you meter the speaker leads behind the HU they are OK, but what does that mean, does it mean that it reads a 4 ohm load and when you check for short chassis ground to each lead, [pos.(+) and neg.(-)] there is no continuity, [no short].
And if you connect the door speaker directly to the HUs speaker output, [and I assume you mean the right speaker output] it does work? 94
Old Nov 16, 2006 | 05:10 PM
dem0nk1d's Avatar
yeah the speaker fires up when you hook it dirrectly to the head units harness. but if i also check for coninuity from the stock harness to the speaker passanger side they read fine..
i will try to take pictures.
Old Nov 17, 2006 | 07:00 AM
fcm's Avatar
fcm
Old Fart
Default Re: (dem0nk1d)
Did you check for continuity to chassis ground, [short] on both speaker leads, if there is no short and you have continuity on the speaker leads, then it must be a connection problem. 94
Old Nov 17, 2006 | 07:48 AM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Is the speaker grounding out when it's installed??</TD></TR></TABLE>
CHANCELLOR12
Audio / Security / Video
Dec 14, 2015 04:48 PM
Chriser0
Mar 21, 2013 07:07 PM
chi_gsr
Aug 12, 2010 04:25 AM
basmasta7
Nov 6, 2008 09:25 AM
vinuneuro
Jun 23, 2006 08:54 PM
