stopped playying
Old Mar 22, 2008 | 02:17 PM
jdmyo21's Avatar
Default stopped playying
my head unit was playing music fine then all of a sudden just stopped playing and wont trun back on...it will show the time and eject/load discs. idk whats going on....help?
Old Mar 22, 2008 | 02:52 PM
94_DC4's Avatar
Default Re: stopped playying (jdmyo21)
What is the MM&Y of the car? Is it the stock radio?
Old Mar 22, 2008 | 04:34 PM
fcm's Avatar
fcm
Old Fart
If the time is correct, check the HU acc. fuse, in the under dash fuse box and in it's acc. lead, if it has one, also make sure the HUs acc. lead is connected properly.
As asked, what is the MM&Y of car, and make and model of HU? 94
Old Mar 22, 2008 | 10:50 PM
suspendedHatch's Avatar
If it's powered up but there's no sound, it's most likely a grounded speaker wire or speaker terminal. This will put the deck into protect mode. Some crappy decks, ie Kenwood, will go into protect mode if you turn them up too loud with too much bass and will need to be reset.
Old Mar 23, 2008 | 09:11 AM
jdmyo21's Avatar
Default Re: stopped playying (suspendedHatch)
how do you reset the head unit???
Old Mar 23, 2008 | 09:12 AM
jdmyo21's Avatar
Default Re: stopped playying (94_DC4)
its a 1997 civic dx and no its a jvc head unit. the model is a jvc kd-s5050j
Modified by jdmyo21 at 11:15 AM 3/23/2008
Old Mar 23, 2008 | 12:44 PM
fcm's Avatar
fcm
Old Fart
Have you checked to see if you have 12V+ acc. on the HUs red lead?
Have you checked the fuses?
You also have not said if the time is correct, or does it reset to 12:00 each time you turn off the ign.?
You said, "...it will show the time and eject/load discs." is that with the ign. on or off?
You can "reset" any HU by disconnecting the batt. neg.(-) cable, wait a few min. and reconnect it.
Most HUs will "initialize" or "power up" when you reconnect the ground to the batt.. all settings will go to default and the CD transport will cycle, [no matter what mode it is in] to the CD ejected mode, [or ready for loading mode, if no disk in the transport].
Please answer all the above questions as accurately as you can, it will make it easier for us to help.
If you do not already have one, here is an owners guide... http://resources.jvc.com/Resou...B.pdf is that the correct one? 94
Old Mar 23, 2008 | 05:17 PM
jdmyo21's Avatar
Default Re: stopped playying (fcm)
well i got it to work it was weird tho i looked at both fuses and they appeared fine but i was outta options so i repalced both of em and it popped on..thanks for all the help though
ScottF
11
Feb 17, 2010 06:27 AM
b16 v8klr
Audio / Security / Video
Jun 9, 2009 04:52 AM
ppfalcon
Sep 7, 2005 08:25 AM
4doorRS5spd
Aug 17, 2002 08:31 PM
