Stop beeping when drivers door is open
Not as nuts as if you forget your lights on and kill the batt. or keys in the ign. and lock your doors.
Why not just remove the keys from the ign. when you "vacuum/detail" the car??? 94
why not install a small toggle switch between the 12v mem wire and 12v acc wire of your radio. then you can turn it on/off with out the key in and dinging.
my civic is power locks you cant lock the drivers side door except from the outside with a key,all others doors lock when you hit the lock button Its pretty much idiot proof, I need to know where the beeping keeps comming from seriously its drivin me nuts!!
don't know if it's different on integras but all my civics had a black rubber thingy inside the door jam below the info-plate that pushed in (on the body)... i would start there.
actually you can, pull out the interior or exterior handle while locking and the drivers door will lock.
here https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-remove-key-ignition-headlights-warning-beeper-2011875/
or why dont you just turn the key to positon 2 and it will only beep a few times and its quiet
on my 2000 accord if you start the car it won't beep... you should try it with yours it would be a lot easier than unhooking the electrical just to vaccuum
portaman03
Honda Civic (2001 - 2005)
Apr 8, 2007 11:04 AM
