Starting out...
Old Jun 11, 2002 | 04:28 PM
SmokyMtnRex's Avatar
New User
Default Starting out...
I am starting out with putting a little stereo together. I want something with a little bit of bass. Something that will thump a little. I don't want to spend a lot of money on the system though. What do you guys recommend. I have a CRX.
Old Jun 11, 2002 | 04:43 PM
UTCiv's Avatar
Default Re: Starting out... (SmokyMtnRex)
If you are looking for just an amp/sub combo i would go with either a single 10 or 12 in a sealed box. You could get a Kicker Comp or Comp VR for a fairly reasonable price and throw it into a small(1.0-1.75 ft^3) box and get a mono or stereo bridgable amplifier (Fosgate Punch s200,s300,m200).
These combos will hit suprisingly well and will offer very little drain on your wallet or electrical system.
These are just some examples of combos which I and my friends have done. Check around and find a combo which meets your desired budget. When you size the amp to the subwoofer try and match the RMS power of the amp at a specific Ohm rating to the RMS power of a certain sub with the same impedance(usually 2,4,8 Ohm or if it has Dual Voice Coils then a 2 ohm DVC could be 1,2,4 ohms or a 4 ohm DVC could be 2,4,8 ohms)
Hope i helped
Old Jun 11, 2002 | 06:44 PM
mooseknuckle's Avatar
Default Re: Starting out... (UTCiv)
do a rockford punch 12"
a small alpine amp like 200watt or so.
and a small box and cables. wont be more then 400.
Old Jun 11, 2002 | 06:46 PM
Anthony K's Avatar
New User
Hope i helped
This would suffice.
vtec8804
Audio / Security / Video
Apr 19, 2007 11:58 AM
97VtecIN
Feb 2, 2005 04:57 PM
AWDxBOOST
Apr 14, 2003 06:59 PM
Nader_D
Jan 23, 2003 09:50 PM
RevedOut
Apr 8, 2002 08:55 PM
