starter kill relay problem
Old Oct 4, 2003 | 11:47 AM
brads94accord's Avatar
Default starter kill relay problem
ok i installed a DEI sidewinder alarm on my car about 2 weeks ago, and its starting to get colder here and now in the mornings when i try to start my car it won't start right away, i have to play with it a little before it will start. it basically just clicks like the power isn't going through the relay. its on a 97 accord lx.
Old Oct 4, 2003 | 01:21 PM
rjr162's Avatar
Default Re: starter kill relay problem (brads94accord)
make sure all your connections are good. If you soldered, make sure you didn't make any cold joints.
Old Oct 4, 2003 | 07:11 PM
TurboBumblBee's Avatar
does it only do it when its remote starting?? i would also check to make sure that your car battery is in good condition cause colder weather in the morning is harder on car batterys.. get a good new battery w/ a high CCA rating
Old Oct 5, 2003 | 05:20 PM
Default Re: starter kill relay problem (Hybrid95CivicEX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid95CivicEX &raquo;</TD></TR><TR><TD CLASS="quote">does it only do it when its remote starting?? i would also check to make sure that your car battery is in good condition cause colder weather in the morning is harder on car batterys.. get a good new battery w/ a high CCA rating</TD></TR></TABLE>
i don't have remote start since my car is a manual. when i installed it, i had to interrupt the wire that runs from the ignition to the starter motor, so basically the current has to run through the relay. i know for sure it has nothing to do with the battery. it just clicks. im gonna try to redo the connections tomorrow. the installation instructions called for a diode on the wire running from the alarm to the relay, i didn't put one in because the install tech guy at hifi-buys and two other local shops said i didn't need it. would that diode have anything to do with it?
Old Oct 13, 2003 | 09:49 AM
well folks, the i re-did the connections several times and the problem didn't go away, and last night my starter finally took a poop, so today i bought another starter, and put it in. ba da bing! the car starts right up!, and when you shake the old starter around it sounds like something is broken inside. moral of the story is, it turned out being a bad starter the whole time.
jkalex05
Aug 31, 2009 10:31 PM
kiklo16
Aug 3, 2007 06:46 AM
eg686
Aug 22, 2005 10:16 PM
85civic
Sep 15, 2004 04:55 PM
Xander teh Grate!
Dec 9, 2003 11:02 AM
