Starter Kill not working on my Compustar..
Old Nov 27, 2003 | 12:00 PM
Vtecfool's Avatar
Default Starter Kill not working on my Compustar..
I just the Compustar 2WSS, and when i lock myself inside the car using the remote and try to start it up.. the only thing that happens is the alarm goes off, and it starts up fine. Do i have to wait like 30sec for the starter kill the work or something? Or did the installer not install it? help!
Oh, and btw.. where is the sensitivity adjustment at? If i just kick the tire the a couple times the full blown alarm will go off.
Old Nov 27, 2003 | 12:17 PM
Toronto90EX's Avatar
Default Re: Starter Kill not working on my Compustar.. (Vtecfool)
There is no delay on the starter kill, once the alarm is armed, the starter kill is active.
Adjustin the shock sensor, is easy on the Compustars, juss look for a egg shaped blk module, its got a dial on it, and dial it up or down. If u can see the brain follow the 4 pin white plug, that should lead u too the module.
Old Nov 27, 2003 | 01:31 PM
EF-Pimp's Avatar
Default Re: Starter Kill not working on my Compustar.. (Toronto90EX)
the one I used to have on my blazer was a fuel cut off thing and would cut off after about 30 seconds so they could get a good 200 feet, thats what happenned the first time and they just left it. Was just a stock 97 blazer that was lowerred with painted rims
Old Nov 27, 2003 | 10:45 PM
Vtecfool's Avatar
Default Re: Starter Kill not working on my Compustar.. (EF-Pimp)
thanks guys. Well, i took bak to the dealer, and they installed a new one or something or reprogramed the brain..so it all work now! Well the sensitivity isn't that bad, cuz in the back if i kick the tires it wont even give off a warning, but if i kick the front it'll go full blown! The installer said the dual shock sensor was in the front of the car so its more sensitive and it'll go off if the car is towed or something..
TripleJ
Apr 5, 2017 01:31 PM
94 accord typeR
Audio / Security / Video
Sep 9, 2014 08:18 AM
pudder
Jan 3, 2008 03:03 PM
cutelilvi3tboig
14
Nov 6, 2004 10:01 PM
CoolKat
Sep 11, 2002 02:16 PM
