splicing wires...
Old May 14, 2005 | 11:49 AM
idriveadelsol7's Avatar
Default splicing wires...
i got a simple question regarding side markers. i'm about to install but i don't know which wires to connect them to. i was thinking, maybe splice the constant wire on the corner lens of me del sol. now will my corner light get more dim? or lose current flow because i spliced it? i want something super bright. thanks.
Modified by idriveadelsol7 at 1:05 PM 5/14/2005
Old May 14, 2005 | 12:18 PM
fcm's Avatar
fcm
Old Fart
Default Re: splicing wires... (idriveadelsol7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idriveadelsol7 &raquo;</TD></TR><TR><TD CLASS="quote">i got a simple question regarding side markers. i'm about to install but i don't know which wires to connect them to. i was thinking, maybe splice the constant wire on the corner lens of me del sol. now will my corner light get more dim? or lose current flow because i spliced it? i want something super bright. thanks.
Modified by idriveadelsol7 at 1:05 PM 5/14/2005</TD></TR></TABLE> Why not just try it, temp. wire the side marker to the batt, then to the corner marker, and see how you like it.
If you want to make sure they, [side markers] are as bright as they can be just add a relay, [off the batt.] and trip the relay with the parklight free pin on the fuse box, you can probably plug the pos. (+) of the side markers, [2] right into the P/L free pin. 94
Old May 14, 2005 | 12:38 PM
Default Re: splicing wires... (fcm)
that's going to suck... i don't want wires all over the place.
Old May 14, 2005 | 08:13 PM
1995Ex_Sedan's Avatar
Just wire them up like they are supposed to be. On with blinkers and on with hazards. They look great. If you try to make them on all the time. I dunno, but I kept blowing fuses. They look great. I used this site.
http://members.***.net/ninety2...r.htm
Old May 14, 2005 | 08:14 PM
Btw, I used wire taps. No soldering. Looks fine, works great. And you dont have to cut the factory wires.
Old May 15, 2005 | 06:40 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idriveadelsol7 &raquo;</TD></TR><TR><TD CLASS="quote">that's going to suck... i don't want wires all over the place.</TD></TR></TABLE> I said temp. = temporarily, you don't need to run any wires to test the light just hook it directly to the batt., [hold the wires to the batt. with your fingers] and temporarily wire the other one the the corner light, that way you will see the diff. then once you see what way you want to do it then hard wire them, and if you take your time, the wiring can be run so Honda would have a hard time telling that they are added. 94
BTW not soldeing and using any kind of quick connect is GETTO!
clean_sol93
Dec 5, 2011 12:59 PM
OziD
Dec 4, 2007 03:48 PM
hbracer93
11
Feb 4, 2006 06:25 AM
Dc2 Powered
Aug 22, 2004 05:50 PM
jdmjeff
Nov 14, 2003 05:56 PM
