speaker size???
Old Nov 20, 2009 | 06:17 AM
  #26
cko37's Avatar
Default Re: speaker size???
It appears as if theres some discrepancies... I have a 1991 crx si and they have 5 1/4 speakers. I replaced them in october myself so this is not a lie... perhaps it is different for other models/years... good luck
Old Nov 20, 2009 | 06:26 AM
  #27
jbrokos307's Avatar
i got 4x6 in my doors cause i gangsta like that lol jk but i do have 4x6 in my doors and they sound like trash i need the plastic spacer for the 6.5 speakers i dont even listen to the radio all i hear is bwaaaaaaaaaah anyway
Old Nov 20, 2009 | 07:41 AM
  #28
WTeFdriver's Avatar
it is 6.5 i just put some in and they bolted straight up...
Old Nov 20, 2009 | 01:07 PM
  #29
attica's Avatar
yeah a 91 crx si
Old Feb 5, 2010 | 12:35 AM
  #30
attica's Avatar
so 6.0 is not it is it 5 1/4?
Old Feb 5, 2010 | 06:27 AM
  #31
cko37's Avatar
If you want to use the stock speaker mounts in your crx, the speaker size is 5 1/4. However, you can fit speakers as large as 6 1/2 inch if you replace the stock speaker mounts and just mount it yourself (via additional drilling, adhesives, etc.) Hope that helps...
Old Feb 5, 2010 | 06:47 AM
  #32
BudIce's Avatar
The reason people say that 5 1/4's are the size (which is incorrect) is because you need to use a "Shallow" mount 6.5". Or you can cut the plastic cup where the magnet hits on a deeper 6.5" speaker and you should be just fine.
Since 1988 in all Civics/CRX's , the fronts have always been 6.5"
And yes the reason why I know, I own quite a few Hondas. I also own my own car audio shop.
Old Feb 5, 2010 | 09:28 AM
  #33
attica's Avatar
yeah because i have 6.0 and my speaker cover does not fit. what are you saying cutting the plastic cup? just snip them out? and it will be ok?
Old Feb 5, 2010 | 09:38 AM
  #34
BudIce's Avatar
Snip the back part out. The part of the plastic that somewhat looks like a vent. Cut them large enough so that the magnet will clear. I just did this on a 91 Prelude the other day too. Factory speakers are very shallow. There are very few aftermarket speakers that are worth anything that are shallow enough. The higher end speakers are deaper and have more magnet.
Old Feb 5, 2010 | 02:05 PM
  #35
fcm's Avatar
fcm
Old Fart
BudIce is correct, kind of...
The stock speaker is a "standard" 6.5", not to be confused with the "oversized" 6.5", a 5.25" speaker will fit, even the 4 mounting screw holes are there, [3 screw holes for the 6.5"].
Stock speaker mounting hole diameter is 5", speaker mounting depth is 2", anything else will need mods, like cutting a hole for the magnet of deeper then 2" standard 6.5", it can add up to 3/4" of more depth, a spacer can also be used to add at least another 1/2" of mounting depth, "hight" of speaker will determine spacer thickness.
As mentioned larger speakers can be installed, up to 7" diameter by 3" deep, to do so the stock plastic speaker housing will need to be replaced with a custom MDF speaker housing, made to fit the bigger speaker.94
Infinity, Pioneer, Eclipse and Alpine all have speaker that will fit, [standard 6.5"]
Although not a "true" standard 6.5" the Infinity REF6032si comes with a mounting ring that allows installation to the stock speaker housing, and it's a pretty good speaker...
http://www.infinitysystems.com/car/p...=US&Region=USA
The Eclipse SE6500 is a direct fit... http://www.eclipse-web.com/us/integrated/se6500.html
The Eclipse SP6510, needs either a spacer or a hole cut, but it is a much better speaker... http://www.eclipse-web.com/us/point/sp6910_6510.html
Like the Eclipse SP6510,the Alpine SPS600 needs a hole cut for the magnet or a spacer, [1/4"]... http://www.alpine-usa.com/product/view/sps-600, although IMO the Eclipse is the better speaker.
The Pioneer TS-G1642R is also a direct fit... http://www.pioneerelectronics.ca/POC...S-G1642R?tab=B Pioneer also has some others. 94
Old Feb 6, 2010 | 12:30 AM
  #36
attica's Avatar
thanks 4 all the help
crxguy406
May 13, 2013 07:38 PM
1991hb
Honda Civic (2006 - 2015)
Jun 13, 2008 08:20 PM
Stealthman80
Honda Civic (2001 - 2005)
Apr 30, 2006 08:28 PM
Bone Stock
Feb 3, 2006 07:43 AM
mr.wong
Audio / Security / Video
Jul 19, 2002 07:30 PM
