SpeaKER HELP!!!
Old Dec 9, 2007 | 12:06 PM
lPat's Avatar
Default SpeaKER HELP!!!
i have a 94 integra gsr....
my 2 front door speakers are not working includeing the factory door tweeters...
anybody know what could be wrong or a way i can fix it
Old Dec 9, 2007 | 01:05 PM
fcm's Avatar
fcm
Old Fart
Default Re: SpeaKER HELP!!! (lPat)
Replace them.
What do you mean "my 2 front door speakers are not working includeing the factory door tweeters..." neither the mid or tweeter on either side is working?
What is driving them, stock HU or something aftermarket, an amp maybe?
If so, what are the makes and models of equipment you have? 94
Old Dec 9, 2007 | 01:53 PM
lPat's Avatar
running off a pioneer deck..
the speakers are good and working but when i put them in the car they dont work, i can put them in the back and they work fine
Old Dec 10, 2007 | 05:55 AM
fcm's Avatar
fcm
Old Fart
Make sure when you install them in the front the speaker terminals are not touching metal, a common problem on Honda/Acura with some aftermarket speakers, connect the speakers without mounting them and see if they work. 94
Old Dec 10, 2007 | 10:54 AM
White Smoke's Avatar
i my honda
Global Mod
Is your stock harness cut behind your HU or are you using a conversion harness? Do you have access to a volt/ohm meter?
Old Dec 10, 2007 | 04:27 PM
lPat's Avatar
Default Re: SpeaKER HELP!!! (White Smoke)
nah the stock harness is not cut i used a wire harness.. i have a multimeter which has ohms and volts and amp but im not that good with it.
Old Dec 10, 2007 | 04:36 PM
fcm's Avatar
fcm
Old Fart
Did you try the speakers not mounted?
Also, you have checked to make sure the HUs fader is not all the way to the rear speakers, right? 94
Killa Vanilla
Audio / Security / Video
Sep 5, 2010 11:10 AM
VTEC_Viking
Jul 9, 2008 12:55 PM
GraphiteMW
18
Dec 9, 2006 05:03 PM
watacivic
Mar 13, 2004 12:45 PM
