Speaker Dent
Old Mar 9, 2010 | 02:16 PM
SoTexDC2's Avatar
Default Speaker Dent
Somehow I managed to dent the this speaker cone. Is there any easy way to pop this back out?
I've tried using tape to pull up on it, not strong enough. I also tried using a shop vac on it but I can't get a good airtight seal around the dent.
I don't want to buy a new component set, I like the way the 6.1's sound. Any ideas?
Old Mar 9, 2010 | 03:50 PM
chawski's Avatar
Default Re: Speaker Dent
its just the dustcap. I wouldnt even worry about it. can you hear any difference out of it? if not, and its covered so its not an eyesore, id just leave it alone
Old Mar 9, 2010 | 04:17 PM
hondadriver's Avatar
never mind, you tried the tape trick thing. Usually works for me with grey tape.
Old Mar 9, 2010 | 06:01 PM
SoTexDC2's Avatar
So that is just a dust cap and shouldn't make any difference? I read online about somebody poking a hole into the center and using an L shaped scribe to pop a similar dent out of an aluminum cone speaker. I'm not sure which would be worse, a dent or a hole in the cone.
I'm not sure if it sounds any different, I haven't been able to listen to it yet. Won't be to that point with the car for a few more weeks..
I tried duct tape, it just isn't sticky enough. I'll give it to infinity, the cone is rather durable.
Old Mar 10, 2010 | 06:47 PM
tazeat's Avatar
At least you weren't as stupid as I was on one of my last cars installing a set of brand new $150 components in the doors I slipped with the screw driver and put it right through the cone . Never even powered up yet. Expensive mistake.
Old Mar 11, 2010 | 02:18 PM
chawski's Avatar
id power it up and see if you can even notice it. if its only cosmetic, id just leave it alone
Old Mar 13, 2010 | 01:00 PM
mikejones100's Avatar
what he said
Accord-Guy
Audio / Security / Video
May 3, 2008 10:58 AM
Al_9000
Apr 5, 2007 08:42 AM
DC4_MADMAN
Jun 20, 2005 02:12 PM
95civickid
10
Mar 9, 2005 07:49 PM
EgSalad
Dec 3, 2004 09:26 PM
