how do you patch a speaker?
Old Mar 5, 2005 | 02:13 AM
95civickid's Avatar
Default how do you patch a sub?
ii have a jl w6v2 and a hole a little bit bigger than the size a quarter but in a triangle shape. just wondering how i could patch it or what could i do to fix it?
Old Mar 5, 2005 | 10:38 AM
PupaScoopa's Avatar
Default Re: how do you patch a sub? (95civickid)
Where is the hole? I once poked a hole in the surround of a woofer with a screwdriver. $75 mistake... If your hole is in the surround, they won't be a diy fix. If it's in the cone, I suppose you could find something stiff and thin to glue to the cone.
Old Mar 5, 2005 | 11:46 AM
95civickid's Avatar
Default Re: how do you patch a sub? (PupaScoopa)
iys in the center of the speaker
Old Mar 6, 2005 | 07:17 PM
c_mack9's Avatar
i had a tear in the cone once and i fixed it with clear finger nail polish. but it wasnt a hole
Old Mar 6, 2005 | 10:21 PM
95civickid's Avatar
Default Re: how do you patch a sub? (c_mack9)
its not re.ally a hole the piece is still atached
Old Mar 7, 2005 | 04:18 PM
B18C_EJ8's Avatar
I don't see why you can't just use some epoxy or other semi-flexible-hardening adhesive and just patch it up. If you can, use some tweezers or something to pull out the flap , glue around the edges, position it back into place and let the glue cure before using. Should be fine...
Old Mar 8, 2005 | 06:39 PM
95civickid's Avatar
Default Re: (B18C_EJ8)
i tried that didnt work to well
Old Mar 8, 2005 | 09:11 PM
aneurysm's Avatar
Default Re: (95civickid)
you can't really patch a speaker cone or surround very well and expect it to sound good, or last too long.
Once they become damaged they pretty much garbage. Any fix or modification changes the weight balange, and movement tolerances of the voicecoil.
Brad
Old Mar 9, 2005 | 10:00 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95civickid &raquo;</TD></TR><TR><TD CLASS="quote">ii have a jl w6v2 and a hole a little bit bigger than the size a quarter but in a triangle shape. just wondering how i could patch it or what could i do to fix it?
</TD></TR></TABLE>I have repaired lots of speakers, I should say temp. fixed.
You need to hit the GF up for some clear nail polish, [or nail repair I think its called] then get some *** wipe, repair the "triangle flap" as best as you can, [using nail polish] then, cut a square of TP, [*** wipe] a little bigger then the "hole" and lay it in, over the "hole", and use lots of nail polish soak the TP, just like laying fiberglass, do one layer on each side, I have had speakers work for years after a repaid 94
Old Mar 9, 2005 | 04:35 PM
DaZman69's Avatar
Default Re: how do you patch a sub? (fcm)
thats a pretty good idea
Old Mar 9, 2005 | 07:49 PM
madlion's Avatar
Default Re: how do you patch a sub? (DaZman69)
if its a small puncture use weed resin.
SoTexDC2
Audio / Security / Video
Mar 13, 2010 01:00 PM
a2dadamm
Paint and Body
15
May 13, 2007 10:13 PM
CBURKE
Welding / Fabrication
Jun 12, 2006 01:31 PM
contender
Feb 4, 2005 09:00 AM
Flux
Apr 1, 2003 07:44 PM
