speaker baffles
Old May 7, 2001 | 03:32 PM
tinter's Avatar
Default speaker baffles
will putting a baffle behind my 6.5" woofer change the sound any?
Old May 7, 2001 | 06:57 PM
crux131's Avatar
Default Re: speaker baffles (tinter)
Hi, I'm new here, but I would say that if it seals off any air leaking around the speaker frame, or stiffens the mounting surface of the speaker, then it would definitely help. It will help improve bass response. Also may want to try to sound deaden your door if you haven't already!
Old May 8, 2001 | 04:05 AM
HondaDriver4Life's Avatar
Tinter....do you have stock or aftermarket speakers and are you considering those foam baffles made by XTC? If so, they will degrade the bass performance of your 6.5" speakers. The reason is that the baffles don't give the speaker enough air-space. When a speaker is in an enclosure that is too small, upper and mid bass frequencies are boosted while low bass frequencies are diminished. This usually results in a sound that is too boomy (over-emphasized in the 80-200Hz range).
If you're worried about water damage to your speakers you can use the baffle as a shield. Cut out the back of the baffle so that it is no longer restricting the air-space of the speaker. If you're not interested in protecting the speaker, then it's better not to use it.
Old May 8, 2001 | 07:28 AM
tinter's Avatar
Default Re: speaker baffles (HondaDriver4Life)
im in the process of installing some mb quarts. ok i guess i wont use baffles. thanks for the info.
rfdphoto
Sep 11, 2012 02:39 AM
madblkscientist
Audio / Security / Video
20
Aug 25, 2009 12:07 PM
JDM_Type-R
17
Aug 18, 2004 07:02 PM
orangegsr
Apr 20, 2004 09:41 AM
GoLowDrew
Jul 12, 2001 03:38 PM
