soundproofing weight issues
Old Feb 7, 2003 | 03:08 PM
redsled00's Avatar
Default soundproofing weight issues
Does putting dynamat or something similar make a difference in wieght? Anyone with experience with this stuff? thanks
Old Feb 7, 2003 | 04:06 PM
Audio28's Avatar
Default Re: soundproofing weight issues (redsled00)
yes it does, depending on how much dynamat you put into your car. If you just get a trunk kit, it's only gonna add couple pounds.
Old Feb 7, 2003 | 11:23 PM
rodimus's Avatar
Default Re: soundproofing weight issues (Audio28)
even if you had 40 lbs worth of dynamat...what does it matter...little if anything.
unless your name is erick aguilar and you're trying to break into the 9's all motor.
and i think 40 lbs of dynamat is ALOT...
my point is ..you probably won't even use THAT much..and if you do...it still won't
really slow you down.
Old Feb 8, 2003 | 12:36 AM
philly-O's Avatar
Default Re: soundproofing weight issues (EVOL)
40lbs of dynamat will be better sounding and more comfortable than "saving" the weight.
Old Feb 8, 2003 | 05:46 AM
b18bEG's Avatar
im useing about 30 sq feet in my car, and its not really that heavy. and if you are using 40lbs of it, i dont think you should be focusing on speed, as much as sound
Old Feb 10, 2003 | 12:07 AM
moridin2004's Avatar
Default Re: soundproofing weight issues (h22akrd)
what is the weight of x amounts of Dynamat? per square foot or what ever. What about Dynamat extreme?
Old Feb 10, 2003 | 04:34 AM
hs2000's Avatar
Default Re: soundproofing weight issues (moridin2004)
go to,
http://b-quiet.com/
you will find all the info you need
Old Feb 10, 2003 | 10:46 AM
o_Rage_o's Avatar
Default Re: soundproofing weight issues (hs2000)
i've put 2 rolls of b-quiet brown bread in my car (stay away from b-quiet extreme...go brownbread)...the package shipping was like 14 pounds..so basically you've added like 30... the diffeerence in comfort vs. the 1/10 on your quartermile doesnt seem to affect me
-rage
Old Feb 10, 2003 | 05:49 PM
redsled00's Avatar
Default Re: soundproofing weight issues (o_Rage_o)
Yeah this weekend I decided why not? So I went to fry's and got the kit for the doors for 50 bux. Instalation time=2 min to take off door panel-15 min to put on dynamat (original)-3 hours for each door trying to put back door panels That was a bitch I ended up taking 3/4 of it off. Oh well. All I can say is that it made a noticable difference. So now since I have a hard on for this stuff I'll probably do the trunk with brown bread or something similar. I don't plan on using dynamat after all you are paying for is the name.
msinsky14
36
Jan 10, 2006 04:21 AM
scorched0
Jan 8, 2004 03:48 AM
allmotorhonda
Jan 2, 2003 04:55 PM
:jdmshmaydm:
Dec 11, 2002 06:34 AM
Apocalypse
Nov 8, 2002 04:45 AM
