Something is wrong with amp?
I have this Rockford Fosgate Power Series 10001 BD amp, i hooked everything up correctly, light turns on but nothing is happening, the sub is not moving at all. Also i notice the remote ring on the amp keeps falling off, there is a hole on the citcuit board, that i can pu back on but it wont stay on tight, could this be a problem? Not sure what the issue is, i didn't really messs with it for long, maybe i need to mess with the options.
P.S. 4 gauge running to dis. block / 8 out, 4gauge ground if u need this information..trying to run at 1000x1 # 2ohm, to a 12w6v2.
Modified by shyboy817 at 6:01 PM 12/3/2004
try another sub, see what happens, if another set of subs don't work then you know it's something in the amp/output of the radio.
Let us Know what happens.
Also, what setup did you have in it before, what did you change, just the amp with same subs/radio/wiring???
P.S. on a 1001BD you should really have 4 gauge going to it...
only had a 600.2 rf amp bridged only making like 200rms watts on the sub.. befor..same everything just changed amps , yeah i i know i should have 4gauge running to it, i can change it i just wanted to test it out first
VTECth1s
Audio / Security / Video
23
May 26, 2011 12:10 PM
