S2000 Stereo Problem
Old May 23, 2004 | 04:28 AM
deanno33's Avatar
Default S2000 Stereo Problem
Since the stock stereos suck in S2000s, I'm sure most have replaced them with aftermarket. I just had Best Buy install a new deck, amp, and speakers in my 2003 S2K. When the car is not started, it sounds awesome. When the car is running, I get distortion and a 'whine' from the stereo. The sound gets worse as the engine revs. The technician says he tried everything (several components, running all wires out side the vehicle...nothing worked). He indicated that it is something in my car causing the problem. Any experience or advice?
thanks all
d
Old May 23, 2004 | 12:13 PM
infinkc's Avatar
Default Re: S2000 Stereo Problem (deanno33)
yea you took it to best buy, its a problem with grounding
Old May 24, 2004 | 10:22 AM
parasonic's Avatar
Default Re: S2000 Stereo Problem (infinkc)
Old May 24, 2004 | 10:32 AM
EFz6er's Avatar
Default Re: S2000 Stereo Problem (parasonic)
Take it back and tell them to re-ground the deck...or if you can do it yourself, do it yourself. But you did pay for "PROFESSIONAL" installation so they should do it for free.
Old May 24, 2004 | 05:39 PM
TurboBumblBee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by infinkc &raquo;</TD></TR><TR><TD CLASS="quote">yea you took it to best buy, its a problem with grounding</TD></TR></TABLE>
yep usually caused by a bad ground in one of the components, more than likely its the amp they installed..
43!
Audio / Security / Video
May 9, 2007 05:50 AM
Irev9g
Honda S2000
18
May 18, 2006 10:18 AM
deanno33
May 30, 2004 11:13 PM
K20A
Honda S2000
11
Mar 5, 2004 12:38 PM
hondaoss
Honda S2000
Feb 1, 2004 10:42 AM
