rockford
Old Mar 13, 2003 | 01:18 PM
GDM Z28's Avatar
Default rockford
hey i got a 500 watt rockford a2(the old style) and its pushing 1 10" L& dual 2 ohm and i have it wired parallel (pos to pos / neg to neg) and then i have it bridged on the amp so its getting a full 500 watts. Its in a sealed box. My prob is the amp gets REALLY REALLY hot. even after like 5 mins of usage. Is it cause i have it running at 1 ohm? should i wire it in series? please help
Old Mar 13, 2003 | 01:26 PM
JOMO
Guest
Posts: n/a
Default Re: rockford (civicflnum1)
i think that might have something to do with it...
you tune yourself?
Old Mar 13, 2003 | 01:55 PM
t0p_sh0tta's Avatar
Default Re: rockford (JOMO)
Is that amp 1 Ohm stable?
Old Mar 13, 2003 | 03:17 PM
koco's Avatar
I think those old Fosgate amps don't really do that well at 1 ohm. In other words , yes that's your problem. 2 ohm might work ok. There's only a handful of amps that run at 1 ohm or 1/2 ohm really well. http://www.usamps.com (open the 2001 product manual and scroll down) has some good technical papers to figure out what ohm load you should run according to the specs on your amp (rail voltage etc.). If you can find good specs for your amp you can do the math.
Does your amp's thermal protection kick in and shut the sound off? I put a cooling fan blowing on my amp because it shuts down. I'm gonna replace it soon though. It runs at 2 ohms.
Old Mar 13, 2003 | 04:59 PM
maxxdout's Avatar
Default Re: rockford (koco)
in general...the older RF amps run really warm. Im not sure about the newer ones.
Old Mar 13, 2003 | 06:30 PM
GDM Z28's Avatar
Default Re: rockford (maxxdout)
thats the thing i didnt know if it was 1 ohm stable or not thats y i asked you guys. Ill bump it to 2 ohm n see what happens. N no the amp doesnt go into protection and i mean it was HOT i couldnt even touch it. i knew they ran warm but not that warm. ill bump it to 2 OHMS and throw a fan on there ty for the help
redline201
Audio / Security / Video
May 25, 2006 08:58 AM
92ehatch
Nov 28, 2005 02:18 AM
b18cEK
Oct 20, 2004 02:51 AM
h22accordr
Jun 6, 2004 12:02 AM
bradykiller
Mar 31, 2004 06:48 PM
