REMOVING TINT!!!
Old Jan 23, 2007 | 09:44 AM
ej8dude's Avatar
Default REMOVING TINT!!!
whats good...i already did asearch on h-t to find how to remov tint...so far i havn't found anything...if you all have any insight on how i can remove my tint it would be great...i hate it...and it looks horrible...
thanx everyone please post what you used and how you did it that would be great\
-chris
Old Jan 23, 2007 | 10:24 AM
B18C_EJ8's Avatar
Razor blade & ammonia worked for me.
Start peeling from one edge, use ammonia to soften adhesive and wipe off. Repeat.
Old Jan 23, 2007 | 11:20 AM
mrdeadman's Avatar
They let me pick
Default Re: REMOVING TINT!!! (ej8dude)
Razor blade, or if you can get ahold of a steamer, that works as well and then just peel it off.
Old Jan 23, 2007 | 12:25 PM
ej8dude's Avatar
Default Re: REMOVING TINT!!! (mrdeadman)
good lookin i was hearing that air craft stripper works as well..anyone???
Old Jan 23, 2007 | 12:29 PM
B18C_EJ8's Avatar
I wouldn't... You wouldn't want to inadvertently drip some on your door and strip the paint.. Also, since the tint is plastic, the stripper will melt the tint and make it into one big gooey sticky mess...
Ammonia may take a tad longer, but it'll be much safer.
I think it took me a little over an hour when I pulled the tint off the front two windows on my Civic.. I used a small spray bottle full of ammonia and sprayed it on generously after I pulled the tint off...
Old Jan 23, 2007 | 12:41 PM
K24EK's Avatar
Heat gun shrinks it and it'll come right off .. I'm a window tinter
Old Jan 23, 2007 | 01:40 PM
RICO_'s Avatar
NO MERCY!
Default Re: REMOVING TINT!!! (K24EK)
I was gonna say that to. The heat gun is usually the easiest method. Takes a little time but it works badass.
Old Jan 23, 2007 | 02:51 PM
technine's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K24EK &raquo;</TD></TR><TR><TD CLASS="quote">Heat gun shrinks it and it'll come right off .. I'm a window tinter</TD></TR></TABLE>
Kinda off topic, but with fingers coming up in the rear window when I put the tint on I get so many fingers that are impossible to get out it seems, would a heat gun and smoothing it out do the trick?
Old Jan 24, 2007 | 01:38 PM
MR_SI's Avatar
Default Re: REMOVING TINT!!! (RICO_)
heat gun a razor blade and patience. hahah the 3rd one is very important in the equation. i had none, and it took longer.
Old Jan 24, 2007 | 03:47 PM
jjmajed's Avatar
Default Re: REMOVING TINT!!! (MR_SI)
I am in the process of taking mine off right now 85% done. Very easy wit ammonia and trash bag in the sun. Took off tint and most glue. The little glue that is left over I went over with steel wool 0000.
Old Jan 24, 2007 | 04:06 PM
joenoreason's Avatar
Default Re: REMOVING TINT!!! (jjmajed)
i just removed my back window tint because it was bubbling and the job/tint quality was so crappy it just peeled right off. but man for some reason it smelled horrible. not sure what it was but it was a strong smell.
Old Jan 24, 2007 | 06:34 PM
allricedout's Avatar
also helps if u have a razor blade handle (like a screwdriver) looks like ---------||
Modified by allricedout at 8:45 PM 1/24/2007
Old Jan 24, 2007 | 06:53 PM
jjmajed's Avatar
Default Re: REMOVING TINT!!! (joenoreason)
yes it smells bad
Modified by jjmajed at 5:30 PM 1/25/2007
Old Jan 24, 2007 | 08:00 PM
alexisthemovie's Avatar
i had mine professionally removed with a steam cleaner. took the guy al and eds about 3 hours and cost me $60.
Old Jan 25, 2007 | 01:54 PM
jjmajed's Avatar
Default Re: (alexisthemovie)
just finished mine
take your time on it
Old Jan 25, 2007 | 03:26 PM
EvenStar's Avatar
the tints are on the inside arent they?
Old Jan 25, 2007 | 05:14 PM
A R M E N .'s Avatar
Default Re: (EvenStar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EvenStar &raquo;</TD></TR><TR><TD CLASS="quote">the tints are on the inside arent they?</TD></TR></TABLE>
lol , naw it's from the outside
Old Jan 25, 2007 | 06:16 PM
jjmajed's Avatar
^^yeah
Old Jan 25, 2007 | 06:21 PM
its just hard to remove tint without ruining the defroster.....near impossible
Old Jan 25, 2007 | 07:30 PM
jjmajed's Avatar
Default Re: (allricedout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allricedout &raquo;</TD></TR><TR><TD CLASS="quote">its just hard to remove tint without ruining the defroster.....near impossible</TD></TR></TABLE>
I didnt have any problem at all, just let let the ammonia soak in with the trashbag method long enough. I didnt even have to scrape anything off. Glue and everything came off.
Old Jan 25, 2007 | 08:04 PM
can u please explain ure method? ^^^^^^^^^^^^^^^^? cuz im really interested
Old Jan 26, 2007 | 12:50 PM
jjmajed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allricedout &raquo;</TD></TR><TR><TD CLASS="quote">can u please explain ure method? ^^^^^^^^^^^^^^^^? cuz im really interested</TD></TR></TABLE>
This is the method I used
http://www.automedia.com/Remov...1tr/1
Old Jan 26, 2007 | 12:55 PM
8520's Avatar
I had a tint shop steam my 20% off on the rear window to replace it with 5%.
Defroster still works perfectly
AzntaggeR
19
Feb 1, 2022 11:31 AM
Egonamikal88
Paint and Body
Jun 24, 2007 01:58 PM
Lan
Aug 28, 2006 05:03 AM
Tizight
Feb 16, 2006 09:20 PM
MachAF
Mar 9, 2003 12:40 PM
