removing clifford alarm
Old 07-03-2006, 04:33 AM
boraVr's Avatar
Default removing clifford alarm
ok right now i have a clifford alarm. i dont really like it so i wanted to remove it. anyone have any tips on removal? and also will my car still have the factory keyless entry? its a 00 civic ex? what my plan was to hope the factory keyless would still be there after the removal of the clifford and to use the automate(dei) 415a along with the factory alarm. so if anyone has any help on this it would be awesome. i have the afternoon off so i have free time.
thanks
Old 07-03-2006, 04:42 AM
john666's Avatar
Default Re: removing clifford alarm (boraVr)
unplug the brain,, if the factory keyless works with out it then it works.. then just remove the actually harness for the alarm
Old 07-03-2006, 10:01 AM
boraVr's Avatar
Default Re: removing clifford alarm (john666)
to remove the harness..do i just cut wires or do i have to follow them and disconnect them? or whats the best way?
thanks
Old 07-03-2006, 10:15 AM
john666's Avatar
well it would look nicer to follow them and disconnect them then tape it up,, im sure if ur real bored heat shrink it or something,
Old 07-03-2006, 10:52 AM
8520's Avatar
Before you do anything, why don't you like your clifford?
Old 07-04-2006, 04:02 AM
boraVr's Avatar
Default Re: removing clifford alarm (a_s_ol_)
well it was someone elses mess(previous owner). there is only one button for unlocking and locking the doors so i can never tell if they are opened or not. there isnt a horn to tell me the doors are locked. so basically its only convient when i am 5ft from the car. not the point of keyless entry, i would rather use the factory set up.
Old 07-04-2006, 08:48 PM
boraVr's Avatar
anyone else have any imput
Old 07-17-2006, 09:23 PM
boraVr's Avatar
ok bringing it back because i just ordered a factory keyless remote. i wanted to know if i unplug the clifford alarm, will i be able to just program the factory remote and everything will work? or will it like cause my car not to start? is that anything i should look out for before i go unpluggin the clifford unit.
thanks
Old 07-17-2006, 10:37 PM
wrx-killer-Sti-eater's Avatar
Location: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
kind of hard to say with out lookind at it. Are there any kill switches that you might not know of ?
Old 07-17-2006, 10:43 PM
suspendedHatch's Avatar
You should probably remove the starter kill relay from the ignition harness and solder the starter wire back together. Then unplug the alarm harness. You can probably pull the whole damn thing out since most installers use those shitty connectors.
Old 07-18-2006, 03:25 AM
boraVr's Avatar
Default Re: removing clifford alarm (suspendedHatch)
the only wiring ive really done on a car was for a radio. any ideas or guides that i should look for for the starter kill relay? or any pictures/diagrams.
thanks
Old 07-18-2006, 04:13 PM
boraVr's Avatar
anyone have any help
thanks alot
Old 07-19-2006, 06:08 AM
fcm
Old Fart
fcm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boraVr &raquo;</TD></TR><TR><TD CLASS="quote">anyone else have any imput</TD></TR></TABLE> What is the model of the alarm, are the park lights not hooked up? The park lights would flash when you arm/disarm the alarm lock/unlock the doors, [normally 1 flash for arm/lock and 2 flashes for disarm/unlock] also the siren should "chirp" once and twice, [chirp may be turned off in programing].
The factory key-less should still work, [once you program a new remote] there is no reason it shouldn't. 94
Old 07-19-2006, 11:59 AM
boraVr's Avatar
Default Re: removing clifford alarm (fcm)
thanks, the lights are hooked up but during the day its hard to see them, and there is no horn.
Old 07-19-2006, 05:19 PM
fcm
Old Fart
fcm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boraVr &raquo;</TD></TR><TR><TD CLASS="quote"> and there is no horn.</TD></TR></TABLE> There is no sound if you trip the alarm?
If the siren has been removed, why not just replace it? 94
Old 07-19-2006, 09:02 PM
boraVr's Avatar
1. i like the factory remote. being that it has a seperate unlock button i can keep pressing it knowing the doors are unlocking.
2. there is a horn but its weird its gone off on me before but not from like a break in kind of situation but from me hitting a button to many times or something i dont remember.
3. i already have sitting in my room the oem seperate alarm system that goes along with the factory keyless
Wimp
03-02-2016 08:27 AM
bart2546
Audio / Security / Video
04-14-2007 02:25 PM
AllMotorDB2
09-30-2006 12:56 PM
BloodStorm
07-07-2005 08:21 AM
OpTiX619
07-28-2004 05:47 PM
Quick Reply: removing clifford alarm
