remote start help
Old Jul 29, 2006 | 10:45 AM
LoveOfMoney's Avatar
Default remote start help
my remote start stopped working. anybody knows here the clutch safety switch is at? a picture would help. im tryin to bypass the clutch. thanks
Old Jul 29, 2006 | 11:49 AM
B18C_EJ8's Avatar
Between the clutch pedal lever and the firewall.
And when you say that it stopped working, what exactly does it do or does not do...
Old Jul 29, 2006 | 07:13 PM
like it was working fine yesterday then today press the button on the pager and wont start up
Old Jul 29, 2006 | 07:28 PM
B18C_EJ8's Avatar
That's not what I asked... I know it doesn't start... I asked what exactly it does... Do the parking lights flash? Do the relays click? Does it crank? What brand/model starter? How do you expect anyone to help if you don't give details???
Old Jul 29, 2006 | 07:45 PM
nothing flashes at all. relays dont click. doesn't crank. i got a clifford rsx 3.5
Old Jul 29, 2006 | 07:57 PM
B18C_EJ8's Avatar
Thank you.
Check to see that your on/off switch hasn't been inadvertently switched off. Check to see that your hoodpin is functioning properly. If those are good, then check the main fuses on the primary harness going to the alarm brain (verify that they're good with a test light or meter, not just by "looking" at them...)
Old Jul 29, 2006 | 08:14 PM
ok, i checked everything. all of the fuses are good. any other suggestion?
Old Jul 29, 2006 | 08:30 PM
B18C_EJ8's Avatar
Try rebooting the unit by unplugging H1 and leaving it for 30 mins, then plug back in.
What y/m/m is this installed in?
Old Jul 29, 2006 | 08:31 PM
1989 crx dx, going to go unplug and see if it works
Old Jul 29, 2006 | 09:59 PM
that didn't work. anything else?
Old Jul 30, 2006 | 06:39 AM
B18C_EJ8's Avatar
Is the transmitter giving you the out of range beep? What's the transmitter doing?
May just have a dead brain... Assuming that you had it installed at an authorized dealer, take it back and have them swap the brain.
Old Jul 30, 2006 | 08:21 AM
i see the transmitter giving signal on my pager. it doesnt give me the out of range beep
Old Jul 30, 2006 | 08:24 AM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">May just have a dead brain... Assuming that you had it installed at an authorized dealer, take it back and have them swap the brain. </TD></TR></TABLE>
Old Jul 30, 2006 | 08:35 AM
i guess im out of luck, because i didn't get it installed at an authorized dealer
Old Jul 30, 2006 | 12:46 PM
8520's Avatar
Default Re: (LoveOfMoney)
Is it in valet mode? Does the siren chirp on arm/disarm?
Old Jul 30, 2006 | 01:07 PM
B18C_EJ8's Avatar
Valet mode shouldn't have anything to do with remote start, should it?? I didn't think valet mode turned the remote start function off, but I'm really not sure... Something to check I guess...
Is the CRX a manual?? How is the clutch bypassed? I know you said that the hoodpin and on/off switch were okay, but I'm still wondering about them... Are the terminals on the on/off switch grounded out? Do you have a hoodpin or mercury switch? I've seen hoodpins fail due to corrosion, but still move up and down...
And like asked above, does the alarm function? LED flash???
Old Jul 30, 2006 | 01:41 PM
8520's Avatar
Default Re: (B18C_EJ8)
My understanding is that valet mode bypasses everything but lock/unlock, but maybe I'm wrong
Old Jul 30, 2006 | 02:41 PM
fcm's Avatar
fcm
Old Fart
Default Re: (a_s_ol_)
Valet mode does not shut down the starter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LoveOfMoney &raquo;</TD></TR><TR><TD CLASS="quote">my remote start stopped working. anybody knows here the clutch safety switch is at? a picture would help. im tryin to bypass the clutch. thanks</TD></TR></TABLE> Try reprogramming the remote... page 34.
To bypass the "Clutch Interlock Switch", connect the BLUE (-) status output wire, [4 pin connector on "Relay Satellite"] to the starter relay side of "CIS"
Let us know how much damage you do the first time you remote start your CRX in gear. 94
ftrms
15
Dec 22, 2010 04:05 PM
94civicdxDD
Jun 15, 2009 11:45 AM
whoa its len 2
Audio / Security / Video
May 5, 2009 01:49 PM
iKhmaiFoSho
Aug 4, 2007 11:36 AM
patastinky
Apr 25, 2004 02:06 PM
