Remote Start (for the creative only)
Old Apr 1, 2005 | 07:18 AM
bigblueandyellow's Avatar
Default Remote Start (for the creative only)
Hey guys, i got myself a 91 hatch with a b16 swap, now i was wondering is there any way that you can set up hood pins or anything to sense when the shift linkage is in gear..........this way when it is in gear the autostart will not engage and i wont find my car burried in a fence or someones house or something.........keep in mind this is to be creative and brackets and **** can be used, just wanna know if someone has done this
Old Apr 1, 2005 | 12:23 PM
fcm's Avatar
fcm
Old Fart
Default Re: Remote Start (bigblueandyellow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigblueandyellow &raquo;</TD></TR><TR><TD CLASS="quote">Hey guys, i got myself a 91 hatch with a b16 swap, now i was wondering is there any way that you can set up hood pins or anything to sense when the shift linkage is in gear..........this way when it is in gear the autostart will not engage and i wont find my car burried in a fence or someones house or something.........keep in mind this is to be creative and brackets and **** can be used, just wanna know if someone has done this</TD></TR></TABLE>Yes it can be done, but why not just get a remote start for manual trans? http://www.compustar.org 94
Old Apr 1, 2005 | 04:28 PM
Default Re: Remote Start (fcm)
oh i got the compustar, i forgot to do a search but i came across all this stuff and the thing called the reservation mode..........in a manual transmission (the brain can tell by the dip switch or the jumper i forget) reservation has to be set or else the car will not autostart "AT ALL!" this is true right??
Old Apr 1, 2005 | 05:07 PM
DaZman69's Avatar
get a turbo timer...set it for like 30 seconds...you will never leave your car in gear
Old Apr 1, 2005 | 06:17 PM
taltares's Avatar
if you gruond your shifter and take 2 springs ( carb. springs) and mount them on top and bottom of the shifter and then take the hood pin wire on the alarm and hook it up the springs. That way if the shifter is up or down if it sees a ground it will not start.
Old Apr 2, 2005 | 06:09 AM
Default Re: Remote Start (taltares)
thats a really good idea...i like it infact im gonna use it!!
thanks
Old Apr 2, 2005 | 11:59 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigblueandyellow &raquo;</TD></TR><TR><TD CLASS="quote">oh i got the compustar, i forgot to do a search but i came across all this stuff and the thing called the reservation mode..........in a manual transmission (the brain can tell by the dip switch or the jumper i forget) reservation has to be set or else the car will not autostart "AT ALL!" this is true right??</TD></TR></TABLE> Yes it is. It's a jumper wire that you do not cut, you will have to, [after parking] step on brake, set E- brake, turn ign. off, car will stay running, open door and get out, [car must be in neutral or you coundn't get out with it running] when the door closes the motor turns off, [unless turbo timer is set] and it arms the alarm and locks the doors, [if its the alarm/starter combo with doorlocks hooked up] if at any time a door is opened, reservation mode will turn off, and would have to be reset, before car will remotely start. 94
narraticon
May 29, 2007 01:20 PM
nekoabandoned
May 9, 2006 05:48 PM
GWMORGAN
Apr 23, 2004 08:23 PM
Fardoche
Aug 11, 2003 06:27 AM
wu tang
Jan 8, 2003 09:22 PM
