Remote Start???
Old Dec 12, 2009 | 01:18 PM
mikeycivic's Avatar
Default Remote Start???
Who makes a decent inexpensive remote start? My fiance wants one and Im looking for something that is reliable and wont break the bank.
Old Dec 13, 2009 | 06:24 AM
mikeycivic's Avatar
Default Re: Remote Start???
Old Dec 13, 2009 | 05:39 PM
fcm's Avatar
fcm
Old Fart
http://www.ultrastarters.com/about.html
http://www.autostart.ca/products.php
Either one, both are inexpensive and dependable, stick with one way units, if anything goes wrong it is almost always with the two-way remotes. 94
Old Dec 14, 2009 | 08:28 PM
HongoRLS's Avatar
viper/hornet good ****
Old Dec 14, 2009 | 08:40 PM
mikeycivic's Avatar
i know that but they arent exactly cheap in price either.
Old Dec 15, 2009 | 03:06 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
5 speed or auto? what kind of car?
Old Dec 15, 2009 | 03:08 AM
http://www.amazon.com/Ready-Remote-2.../dp/B0015ASLXW
Old Dec 15, 2009 | 06:04 AM
mikeycivic's Avatar
03 jeep liberty automatic, and desmon please contact me AGAIN.
Old Dec 15, 2009 | 01:21 PM
stock2mal's Avatar
Are you planning on installing it yourself, or will you be taking it to a shop?
Old Dec 15, 2009 | 01:50 PM
suspendedHatch's Avatar
So you post for advice, and wrx-killer contacts you to offer you to buy an alarm from him. Do I have that right?
Old Dec 15, 2009 | 04:51 PM
mikeycivic's Avatar
wow you got it out for him morton? I will be installing it myself
Old Dec 15, 2009 | 06:40 PM
Yea, dude has some kind of thing or whatever. Funny thing is that I did not try to sell you anything. Hell I sent you a link to a cheap unit for you to purchase. I guess reading owns him. Mike I just sent you a pm if you need a tech sheet from dei to help you out.
Old Dec 15, 2009 | 06:50 PM
Send to Printer Close Window
2003 Jeep Liberty DirectWire 2.0 Vehicle Information
Remote Start
Item Wire Color Polarity Wire Location
12 Volts red & pink/black + ignition harness
Second 12 Volts
Starter yellow + ignition harness
Second Starter N/A
Ignition red/blue + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory black/orange + ignition harness
Second Accessory black/white + ignition harness
Third Accessory
Keysense lt. blue - ignition harness
Data Bus
Can Bus High
Can Bus Low
Can Bus Sw
Power Lock pink/purple - back of fusebox
Lock is negative trigger thru a 1.4K ohm resistor and unlock is negative trigger thru a 426 ohm resistor. MUST use relays. In the top left corner in a black plug.
Power Unlock same wire as power lock
Lock Motor orange/black 5wi back of fusebox
Driver Unlock Motor pink/black 5wi back of fusebox
Parking Lights (-) lt. green/orange - headlight switch
Parking lights is negative trigger thru a 910 ohm resistor. MUST use a relay.
Parking Lights (+) DO NOT USE
Hazards
Turn Signal (Left)
Turn Signal (Right)
Headlight lt. green/orange - headlight switch
Headlights is negative trigger thru a 349 ohm resistor. MUST use a relay.
AutoLights
Reverse Light brown/lt. green + DKP, 72 pin plug, pin 48
Left Front Door Trigger see notes - BCM
The LF door is tan in conn. 1, pin 4. The RF door is tan/red in conn. 1, pin 5. The LR door is tan/orange in conn. 2, pin 3. The RR door is tan/yellow in conn. 1, pin 22. Use all four wires and diode isolate each. The BCM (Body Control Module) is attached to the left of the fusebox. Connector 1 is a gray 26 pin plug, and connector 2 is a gray 22 pin plug.
Right Front Door Trigger
Left Rear Door Trigger
Right Rear Door Trigger
Dome Supervision use door trigger
Trunk/Hatch Pin tan/black - conn. 1, pin 7 @ BCM
The flip up glass pin switch is yellow/white in conn. 1, pin 9 of the BCM. The BCM (Body Control Module) is attached to the left of the fusebox. Connector 1 is a gray 26 pin plug, and connector 2 is a gray 22 pin plug.
Rear Glass Pin
Hood Pin brown/tan - conn. 1, pin 6 @ BCM
Trunk/Hatch Release orange/pink - conn. 1, pin 17 @ BCM
Trunk Release Motor
Fuel Door Release
Power Sliding Door (Left) N/A
Power Sliding Door (Right)
Factory Alarm Arm
Factory Alarm Disarm lt. green/orange - conn. 2, pin 9 @ BCM
The factory alarm disarm is negative trigger thru a 473 ohm resistor. MUST use a relay. The BCM (Body Control Module) is attached to the left of the fusebox. Connector 1 is a gray 26 pin plug, and connector 2 is a gray 22 pin plug.
Disarm No Unlock see factory alarm disarm
Trunk Alarm Shunt
Tachometer NOT grn/org or org/grn ac ign coil, coil pack, or injector
Wait to Start N/A
Neutral Safety
Clutch Pedal
Fuel Pump
Rear Defroster
Mirror Defroster
Left Front Heated Seat
Right Front Heated Seat
Speed Sense lt. green/yellow conn. 1, pin 20 @ BCM
Brake Wire white/tan + brake pedal switch
Parking Brake gray/black - parking brake switch
Horn Trigger black/red - steering column
Wipers brn/wht (L), red/yel (H) + windshield wiper motor
Memory Seat 1
Memory Seat 2
Memory Seat 3
Smart Starter Kill Relay
Relay Type:
Part #:
OE Relay Part #:
n/a
n/a
n/a
Notes:
n/a
Alternate Part Notes:
n/a
Interface Modules
SKU Module Description Upgradeable Keys Required for Programming Keys Required for Operation
XK531 Programmable Platform#531:Door Lock Control + RF Override / Firmware: CHDL4 1.00 Yes 2 0
DLPKCHG1 DLPKCHG1 -PLATFORM #3 Doorlock & Bypass: 1ST GEN CHRYS / Firmware: 11.CHRY4 1.03 Yes 2 0
PKCH1 Chrysler Gen1 RF transponder bypass No 2 2
XKEYCH Encrypted 1st Generation Chrysler transponder key No 2 0
RFLCH RFloop for GEN 1 Chrysler No 2 0
TBXKEY Universal Transponder bypass No 0 1
555CW CHRYSLER 1st Gen SENTRY-KEY RF TRANSPONDER BYPASSKIT No 2 0
556UW UNIVERSAL REMOTE START INTERFACE W/ SELECTABLE WINDINGS No 0 1
29402 UNIVERSAL TRANSPONDER BYPASS: READY REMOTE CLAMPACK No 0 1
556U UNIVERSAL TRANSPONDER BYPASS: IGN KEY REQ'D CLAMPACK No 0 1
20402 UNIVERSAL TRANSPONDER BYPASS: IGNITION KEY REQUIRED No 0 1
XK03 Programmable Platform #03: Doorlock & Alarm Interface / Firmware: CHDL4 1.00 Yes 1 0
456LW UNIVERSAL DOOR LOCK RESISTANCE LEARNING MODULE / Firmware: CHDL4 1.00 No 0 0
456LW UNIVERSAL DOOR LOCK RESISTANCE LEARNING MODULE No 0 0
© 2007 Directed Electronics. All Rights Reserved.
DirectWire and its vehicle information are for the sole use of authorized Directed Electronics personnel and it's participating dealers and distributors. The information contained on these pages may contain confidential and privileged information. Any unauthorized review, use, disclosure or distribution is prohibited.
O I sorry but this diagram will cost you about $45.67. Please make that cash in hand.
Old Dec 15, 2009 | 07:57 PM
mikeycivic's Avatar
wtf is all this ^^^ LOL
Old Dec 16, 2009 | 03:59 AM
Its the wire diagram for your ladys truck! The money part was a joke
Old Dec 16, 2009 | 06:19 AM
mikeycivic's Avatar
wow that looks extensive, thanks des
Old Dec 17, 2009 | 06:47 AM
stock2mal's Avatar
I recommend using a data module for this vehicle to avoid all the resistor work. Makes your job a lot easier.
Old Dec 18, 2009 | 09:14 AM
Tim2179's Avatar
eight equals equals equals D
Community Builder
Loved
On the same topic - I'm thinking about getting a remote starter for my GF's '04 Civic. Is it a bad idea to purchase one from Best Buy and have them install it?
One thing I'm concerned about is that she has a factory alarm and I'm wondering if that will cause any problems with a remote starter. Ideally I'd like to be able to have the alarm armed, remote start the car, and then disable the alarm when she's ready to roll.
Old Dec 18, 2009 | 11:06 AM
fcm's Avatar
fcm
Old Fart
I will have to check if the bypass modules we use has the alarm arm/disarm in it, otherwise it works only with the OEM remote.
I will let you know after work. 94
Old Dec 18, 2009 | 12:13 PM
mikeycivic's Avatar
ok well whats the easiest way to install one in my fiance's car?
Old Dec 18, 2009 | 04:24 PM
fcm's Avatar
fcm
Old Fart
Fortin does not have a module that will deal with the alarm... http://ifar.ca/en/vehicles/honda/civic/2004/ they will only bypass the immobilizer... http://64.85.6.121/diagrams/printpag...18684&MakeID=3
I will have to check the new modules that are coming out.
Or you could just install an alarm/remote start combo unit and ditch the stock alarm, it's not much good anyway. 94
baller862
Audio / Security / Video
Mar 17, 2009 08:03 PM
akaEsCo01
Honda Civic (2001 - 2005)
17
Dec 28, 2007 05:29 AM
FastAsleep
Dec 26, 2007 09:03 AM
mnskateboarder
Jan 26, 2004 04:11 PM
SMZ GSR
Dec 30, 2002 02:02 PM
