Remote Signal Strength Increase?
Old Mar 1, 2009 | 08:02 PM
tyronne1126's Avatar
Default Remote Signal Strength Increase?
is there any way to increase the range of the keyless remotes?
can i just extend the antenna wire and put it close to the window?
i cant get more than 10feet.. and it has to be clear passage.
Old Mar 1, 2009 | 08:05 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: Remote Signal Strength Increase?
make model of alarm, extending the wire will not incress range. Most of the time the wire lenght is tunned to the alarm. make sure there are fresh batteries on the remote and the alarm has a good ground
Old Mar 1, 2009 | 08:13 PM
everything is brand new and i made sure the ground was good haha i had to.. that was the reason it wasn't working at all in the beginning
Old Mar 1, 2009 | 08:17 PM
You can try it. I can't say that it will make it better.
Old Mar 3, 2009 | 05:12 AM
audioroach's Avatar
Do you have window tint?
Good quality tint has a high metallic content in it which can effect radio waves (ie alarm remotes)
Is the antenna centered behind the rear view mirror?
This location typically gives the best range of reception.
Does it happen in the same location (poor reception) or does it work fine other places or is it a constant situation?
If its happening in the same location you may have a larger radio signal effecting reception...if not check batteries install etc.
Old Mar 3, 2009 | 09:22 AM
well no.. its a very simple keyless and has a wire to do it. Aftermarket. So its installed under the dash. and yes i have window tint but its actually not a good brand. i can tell that its going to eventually turn purple.. (need to replace it soon) .. i guess im just stuck with the range i got.. its all good.. i just wanted to know if there was a way to get better signal..
ninjarich2
Audio / Security / Video
Mar 16, 2007 10:05 AM
Jdmglenn
Oct 20, 2006 05:38 PM
flatblack-h22
Jul 12, 2006 10:30 PM
SilverDc2
11
Jun 26, 2003 10:34 PM
