Rear speaker mounting solution
Old May 26, 2007 | 12:24 PM
ThinkRevolution's Avatar
Default Rear speaker mounting solution
I have no rear speakers in my CX, i'm not sure if there ever were speakers, but when I bought the car there were none.
The interior is stripped.
I would like to install rear speakers, but i'm perplexed as to what to do to mount them. I took it to a shop today, and he said that mounting them to nothing would make the entire thing sound like **** and to come back to him when the car is back together.
I'm sure other people have been in my shoes, what did you guys do?
Old May 26, 2007 | 03:31 PM
chrisw85's Avatar
get a pair of 6x9 enclosures for like $40. Velcro or screws for now until you get your interior together.
Old May 28, 2007 | 11:50 AM
CB7.v2's Avatar
if you have an eg, then you could get these brackets. not sure if the interior panel is already perforated; if not, cut a hole and use the included grills.
Old May 28, 2007 | 11:52 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (CB7.v2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisw85 &raquo;</TD></TR><TR><TD CLASS="quote">get a pair of 6x9 enclosures for like $40. Velcro or screws for now until you get your interior together.</TD></TR></TABLE>
Horrible idea.
Get the factory rear-speaker kit.
Old May 28, 2007 | 04:46 PM
chrisw85's Avatar
Default Re: (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">
Horrible idea.
Get the factory rear-speaker kit. </TD></TR></TABLE>
If his interior is stripped, then those speaker brackets aren't going to look all that great in the rear, it'll be 'infinite baffle' with exposed wires etc.
I myself would worry more about the front stage SQ than any rear-fill.
Old May 28, 2007 | 05:35 PM
fcm's Avatar
fcm
Old Fart
Default Re: Rear speaker mounting solution (ThinkRevolution)
I myself would worry more about the front stage SQ than any rear-fill.</TD></TR></TABLE> Ditto the above
ThinkRevolution How "stripped" is your CX, [BTW for us no0bs, what is a CX, MM&Y?] does it include the door panels?
I agree with chrisw85 you should concentrate your time and money on the front stage of your system, even if the door panels are not there, they are not needed for good sound and would have to be removed to install speakers properly, [for best SQ], rear speakers can be added later but are not required.
If you do want to install rear speakers, install a set of mid-range/mid-bass drivers, no tweeters and if possible wire in mono.
Even better, install a set of subs, unless you want to shake the ground you can get very good sub bass from a pair of 8", even a pair of 6" without taking up any space in the pass. compartment. 94
Old May 30, 2007 | 10:26 AM
Default Re: Rear speaker mounting solution (fcm)
I was thinking about getting those brackets..
The car is completely stripped but DOES have the front door panels.
What are part numbers that I would need to get both rear brackets and what I need to mount them?
They are 6.5 no? Or can I fit bigger ones?
Old May 30, 2007 | 10:53 AM
suspendedHatch's Avatar
The point is that you have to seperate the sound wave that's coming off the front of the speaker from the sound wave firing out the back of the speaker. If you don't, you will get all kinds of cancellation. Your 6x9s will sound like 3 inchers.
Old May 30, 2007 | 09:50 PM
Default Re: Rear speaker mounting solution (suspendedHatch)
well the way i'm looking at it, i'm better off with SOMETHING.
The car is so loud as is (road noise) I have to crank up the speakers just to hear anything
Old May 30, 2007 | 09:59 PM
chrisw85's Avatar
Front stage, sound deadening, and sound deadening. Get some front components that can handle about 100w-150w rms and throw some power at them. You'd be surprised how much sound and volume you can get with proper sound deadening and some good but inexpensive components. Think convertibles, like the S2k, lots of road noise i'm sure more than youre stripped interior hatch. The front doors and the rear wheel wells make the biggest contributer to road noise so thats what I'd deaden on your hatch. Something is better than nothing, even if it is only 45mil butyl rubber stuff.
Old May 30, 2007 | 10:42 PM
Ran4it2's Avatar
i have a cx also
i never put in rear speakers but i put in REALLY nice components in the front pioneers i forget the model
thats what i suggest to u
david22ky
Aug 6, 2007 09:27 AM
ThinkRevolution
May 25, 2007 06:52 PM
robinsf
Mar 20, 2007 11:41 AM
Vistage
Jan 5, 2007 08:18 PM
boredracer408
Audio / Security / Video
Mar 3, 2004 12:25 PM
