Rear Deck problems.
Old Jun 23, 2004 | 09:29 PM
eL's Avatar
eL
Default Rear Deck problems.
When I got my car I noticed the part of the rear deck where the speakers are supposed to fit was all ripped up and left with uneven and jagged metal like someone ripped the speakers out once with a claw hammer!
Is there any way I could fix this so I could get my speakers to sit securely? They're on there using like maybe 1 screw. I would like to fix this to make it all look much neater.
Thanks
Old Jun 24, 2004 | 06:36 AM
EFz6er's Avatar
Default Re: Rear Deck problems. (eL)
Find a new rear deck
Old Jun 24, 2004 | 06:01 PM
loulax07's Avatar
Default Re: Rear Deck problems. (puddz27)
You could always get some mdf wood, maybe 1/4" or 1/2" and fabricate a new mounting ring that gets fastened to the sheet metal and the speaker mounts into it.
Then silicon the edges/gaps where they meet
Old Jun 25, 2004 | 07:32 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eL &raquo;</TD></TR><TR><TD CLASS="quote">When I got my car I noticed the part of the rear deck where the speakers are supposed to fit was all ripped up and left with uneven and jagged metal like someone ripped the speakers out once with a claw hammer!
Thanks </TD></TR></TABLE>
Someone has installed larger then OEM speakers there at some point,[and did a **** poor job of it ]
A MDF panel will work , but use 3/4" or 1" , the 3 main rules for mounting speakers are 1- mount speaker to flat surface
2- have airtight seal between front and back of speaker
3- mass, the more mass the speaker is mounted to the better
A flat surface will keep speaker from "twisting" , airtight seal will help power handleing and frq.responce [lower -3db point], mass makes speaker more efficient,[ if the whole speaker can move backwards when cone is driven forward you are wasting power], also a speaker mounted to wood, will always sound better then a speaker mountad to sheetmeta.
hope this helps 94l
Old Jul 6, 2004 | 09:53 AM
eL's Avatar
eL
thanks for the replys everyone...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by puddz27 &raquo;</TD></TR><TR><TD CLASS="quote">Find a new rear deck</TD></TR></TABLE>
Is it possible to just switch them? Does it even come out at all?
Old Jul 6, 2004 | 07:17 PM
fcm's Avatar
fcm
Old Fart
Is it possible to just switch them? Does it even come out at all?[/QUOTE]
If you mean the rear trim,[parcel shelf] YES andYES If you mean the sheetmetal under the trim NO and NO
Max Q
Acura TL, RL & ZDX
Jan 23, 2013 04:33 PM
clewis3
Mar 22, 2010 08:17 AM
HondaGSX
Honda Civic (2006 - 2015)
19
Nov 4, 2006 07:50 AM
bassisliffe
Audio / Security / Video
71
Jun 28, 2004 07:32 PM
Hcivic88
Apr 28, 2002 06:53 AM
