rca's and speaker wire...
Old Aug 19, 2004 | 07:15 PM
ilikemyaccord's Avatar
Default rca's and speaker wire...
i have a buzz noice sometimes when i listen to my music. i heard that if you set the rca's and speaker wire next to each other it does that? should i run the 3 sets of rcas from one side of my car to the amp in the back and the speaker wire on the other side? thanks all
Old Aug 19, 2004 | 11:20 PM
hybridzOr's Avatar
Default Re: rca's and speaker wire... (ilikemyaccord)
try a ground loop isolator.
Old Aug 20, 2004 | 06:32 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ilikemyaccord &raquo;</TD></TR><TR><TD CLASS="quote">i have a buzz noice sometimes when i listen to my music. i heard that if you set the rca's and speaker wire next to each other it does that? should i run the 3 sets of rcas from one side of my car to the amp in the back and the speaker wire on the other side? thanks all</TD></TR></TABLE> That would be RCAs and power wires run next to each other, run your RCAs down center of car, run power down batt. side of car, run speaker wire with RCAs, do not twist any wires together, run them parallel to each other, the trick is to keep power away,[any power] from signal and keep all cable and wire as short as possible.
hope this helps. 94
Old Aug 20, 2004 | 07:18 AM
debogsr's Avatar
Default Re: rca's and speaker wire... (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> That would be RCAs and power wires run next to each other, run your RCAs down center of car, run power down batt. side of car, run speaker wire with RCAs, do not twist any wires together, run them parallel to each other, the trick is to keep power away,[any power] from signal and keep all cable and wire as short as possible.
hope this helps. 94</TD></TR></TABLE>
yeah, It was easier for me to run the rca's down the drivers side instead of the center of the car, but same point.
Old Aug 20, 2004 | 01:37 PM
Default Re: rca's and speaker wire... (debogsr)
ok..thanks guys....ill seperate the wires. but its okay for power and speaker wire to be next to one another?
Old Aug 20, 2004 | 02:25 PM
debogsr's Avatar
power and speaker wire? explain please. The power wire goes to the amp, and the speaker wire runs to the subs or speakers. How would you get them crossed next to each other? But either way, i always thought you try to seclude the power wire... but i not sure
Old Aug 21, 2004 | 12:07 AM
power wire...coming from the battery goes through the right side of my car under the panels. i recently purchased a new headunit and an amp to power my speakers. so we split the speaker wires from the headunit harness and carried them on the right side on my car also to the amp in the back. and the rca's also. so to avoid the buzz, i keep the rca's seperated so move it on the left side and bring it all the way back to my amp?
Old Aug 21, 2004 | 12:24 AM
ihyperxboy's Avatar
it may be as simple as the type of wires you are running...what brand are you using?
Old Aug 21, 2004 | 12:30 AM
Default Re: rca's and speaker wire... (ihyperxboy)
****, idunno. 2 of the rca's came from a mom and pop shop and the other from an amp kit. what rca's should i buy?
Old Aug 21, 2004 | 06:48 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ilikemyaccord &raquo;</TD></TR><TR><TD CLASS="quote">****, idunno. 2 of the rca's came from a mom and pop shop and the other from an amp kit. what rca's should i buy?</TD></TR></TABLE> Ok one more time, the best way to run wireing in your car, the RCAs,[ 100% shield or dbl shielded car audio cable, $10 to $15 each] you can spend a lot more, but no need to. run the RCAs down the center of car,[ that will keep them away from any power wire] you can also run speaker wire with the RCAs, run the power wire for the amp down the batt. side of car,[ if batt. is on drivers side run power down drivers side,if on pass. side run it down pass. side] the trick is to keep everything as short as possible, you can also run the RCAs and speaker wire down the pass. side of car, and run the power down the drivers side, this will make the runs longer by 2 to 4 feet for the RCAs,[ depending on where amp/s are] the power wire will be 4 to 6 feet longer if batt. is on pass. side of car.
hope this helps. 94
Old Aug 21, 2004 | 12:43 PM
Utilitarian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> Ok one more time, the best way to run wireing in your car, the RCAs,[ 100% shield or dbl shielded car audio cable, $10 to $15 each] you can spend a lot more, but no need to. run the RCAs down the center of car,[ that will keep them away from any power wire] you can also run speaker wire with the RCAs, run the power wire for the amp down the batt. side of car,[ if batt. is on drivers side run power down drivers side,if on pass. side run it down pass. side] the trick is to keep everything as short as possible, you can also run the RCAs and speaker wire down the pass. side of car, and run the power down the drivers side, this will make the runs longer by 2 to 4 feet for the RCAs,[ depending on where amp/s are] the power wire will be 4 to 6 feet longer if batt. is on pass. side of car.
Definately. Run the RCA's right under the console.
Old Aug 21, 2004 | 05:58 PM
bassisliffe's Avatar
Default Re: rca's and speaker wire... (Utilitarian)
it will pick up noise from the fuel pump there, do like me and run it up on the rear veiw mirror and ono the ceiling then hang right onto your amp
but you have to use the cool blue ones
Old Aug 22, 2004 | 09:35 AM
fcm's Avatar
fcm
Old Fart
Default Re: rca's and speaker wire... (bassisliffe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bassisliffe &raquo;</TD></TR><TR><TD CLASS="quote">it will pick up noise from the fuel pump there, do like me and run it up on the rear veiw mirror and ono the ceiling then hang right onto your amp
but you have to use the cool blue ones </TD></TR></TABLE> What? again, bass you are not helping, I have run 1000s of RCAs down center of car and have never picked up noise from a fuel pump, maybe its the "cool blue ones" lol. 94
Old Aug 22, 2004 | 10:00 AM
lol yeah it happened to me once id turn on the ignition and hear the pump firing up
but it wasn't the cool blue ones it was the cool yellow ones
sound barrier yellow rcas suck ***
Old Aug 22, 2004 | 07:20 PM
just hooked up my new amp and sub....god dam the buzz gets loud when i accelerate my car...i just humms when the car is on and stops when i remove the faceplate. my best bet is to just throw the rca's down the car on the opposite side of the power wire?...its annoying
Old Aug 22, 2004 | 09:26 PM
keemosaki's Avatar
your picking up engine noise through your rca's... Did you run the RCA's the same side as the power wire?
Old Aug 23, 2004 | 11:35 AM
Default Re: rca's and speaker wire... (keemosaki)
yes i did
Old Aug 23, 2004 | 12:27 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ilikemyaccord &raquo;</TD></TR><TR><TD CLASS="quote">yes i did</TD></TR></TABLE> Do not run the RCAs with the power lead
also do not run RCAs an left side of car, that is the "power" side of car, most if not all wireing for brake,tail, sig, and backup lights run down the left side. 94
Old Aug 23, 2004 | 01:17 PM
throw it down the middle of my car?..its a bitch to get under the carpet. should i just put the power wire down the left side of my car even though the battery is on the passenger side?...do all the electrical wires and power wire down the left side and rca's and speaker wires down the right side?..(passenger)
Old Aug 23, 2004 | 01:27 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ilikemyaccord &raquo;</TD></TR><TR><TD CLASS="quote">throw it down the middle of my car?..its a bitch to get under the carpet. should i just put the power wire down the left side of my car even though the battery is on the passenger side?...do all the electrical wires and power wire down the left side and rca's and speaker wires down the right side?..(passenger)</TD></TR></TABLE> Yea you will have to remove pass.seat , rear seat and consol and some trim, yes you can run power down left side and RCAs and speaker
wire down right. 94
Old Aug 23, 2004 | 02:12 PM
keemosaki's Avatar
yes sir
Old Aug 23, 2004 | 06:40 PM
b16a2pwrd's Avatar
jesus ladies, heres the deal. Yes wires do make a difference. radio **** shack wires do not cut it. you dont have to spend alot of loot but for gods sake, dont be cheap. in almost all hondas the battery and a nice big fat empty gromet is on the passenger side, newer rides are a little tighter and funkier. running rcas down the "power" side does not make a difference unless you use said **** shack wires. running rcas and power wire together is not the best idea, but then again crappy equipment, wires and install can create noise. if youre gonna put equipment in, learn to troubleshoot.
Old Aug 24, 2004 | 05:35 AM
Default Re: rca's and speaker wire... (b16a2pwrd)
i got rid of my engine noise by grounding the battery to the chassis with 2awg wire
can anyone explain this!? it happened by accident, i thought my hu was shot as i couldnt get rid oof it, i had a 2awg equipment ground wire and just decided to try it on the battery to chasis
i was driving and realised all engine noise was gone, wow!
Old Aug 24, 2004 | 07:11 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bassisliffe &raquo;</TD></TR><TR><TD CLASS="quote">i got rid of my engine noise by grounding the battery to the chassis with 2awg wire
i was driving and realised all engine noise was gone, wow!</TD></TR></TABLE> Increased current flow. 94
Old Aug 24, 2004 | 09:54 AM
it came back
