radio station is all staticy
Old Jul 12, 2004 | 06:58 PM
Kyles ej1's Avatar
Default radio station is all staticy
the radio doesnt work but he cd player does. the antenna plug is plugged into the back of the deck but the all the radio stations are staticy. any knoe whats wrong and how i can fix it? 93 civic
Old Jul 12, 2004 | 08:12 PM
Kyles ej1's Avatar
Default Re: radio station is all staticy (egcoupe)
anyone?
Old Jul 13, 2004 | 04:28 PM
livelife46290's Avatar
Im not quite sure what might be wrong, do you have an automatic antenna that raises up and down or do you have a solid mast antenna? That would be where i would start, once you answer that I can continue speculating on what may be wrong!
Old Jul 13, 2004 | 11:56 PM
Kyles ej1's Avatar
Default Re: (livelife46290)
its not anautomatic on so i guess it s the other. the one u have to pull up
Old Jul 14, 2004 | 05:10 AM
Make sure you have it pulled up all the way and then check to see if the wire hasnt become disconnected from the antenna its self, thats a possibility, or maybe there is even a small cut in the wire making it come in contact with something and turning the whole car into a giant static antenna.
Old Jul 14, 2004 | 06:59 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcoupe &raquo;</TD></TR><TR><TD CLASS="quote">the radio doesnt work but he cd player does. the antenna plug is plugged into the back of the deck but the all the radio stations are staticy. any knoe whats wrong and how i can fix it? 93 civic</TD></TR></TABLE> Did the oem HU radio work? if so your HU, if not its the ant., you need a multimeter to test ant., although most problems with ant. is grounding, try this, remove 2 screws that hold base of ant. onto car, pull ant. housing out of mt. hole about 1 to 3 inchs, do not force, check under base that cable is attatched and ground strap, [ thin metal strap running from were cable is attatched up to mt. base] is good ,if all good replace screws tighten.
hope this helps 94
TB123
Audio / Security / Video
May 9, 2007 01:17 PM
tqhill3
Mar 3, 2004 05:14 PM
spoonb18b
Feb 21, 2004 08:14 PM
sonicblueteg2k
Feb 7, 2003 10:57 PM
