Radio Removal
Old Oct 27, 2005 | 05:05 PM
flir's Avatar
Default Radio Removal
I removed the battery in my daughters 2002 civic and lost the radio code. I need to remove the radio to get the serial number. Is anyone familiar with removing it? How do I go about removing it?
Paul
Old Oct 27, 2005 | 08:36 PM
ninhers's Avatar
Default Re: Radio Removal (flir)
if it is a 02, try looking in or around the glove box. there should be a sticker that has numbers on it. that should be the sn for the radio.
Old Oct 28, 2005 | 02:11 AM
eastsidecustomz's Avatar
Default Re: Radio Removal (ninhers)
and if not lower your glove, and you will see 2-3 screws you must un do, on the center console on the right side, then on the driver side, there should be another two screw, the rest is pop off pin wher eyour cigarette lighter is pull it out and there should be 2 8mm screws to pull out after takign those out, pul the hole unit as one out and disconnect your harnesses
omarisramo
Apr 26, 2008 09:54 AM
flashintheleather
Audio / Security / Video
Oct 13, 2006 12:40 PM
SiSpopu
Acura TL, RL & ZDX
Jul 7, 2006 09:33 AM
Loveless
Acura TL, RL & ZDX
Jan 31, 2006 11:06 AM
friscorice88
Dec 13, 2005 08:40 PM
