radio removal help
Old Oct 13, 2006 | 09:21 AM
flashintheleather's Avatar
Default radio removal help
hey guys, I have a 2002 Accord EX and I recently disconnected my battery, meaning I need to get the code for the stock radio to work again. any help you guys can offer on removing the radio and getting the serial number from it? also, I would like to someday add on to my audio system in the car, but I would also like to keep my factory six disck changer? will I still be ok. Thanks a bunch in advance.
Old Oct 13, 2006 | 10:05 AM
02 accord's Avatar
Default Re: radio removal help (flashintheleather)
Look in the glove box for a 5 digit number. That would be your radio security code.
Old Oct 13, 2006 | 11:06 AM
B18C_EJ8's Avatar
If the code's not there (which is probably isn't), then to remove the radio, you'll need to remove two philips screws from bottom edge of the climate control/radio bezel. Then, with a small flat head screwdriver, GENTLY pop out the clock by prying from the left or right edge to expose one philips screw. Remove that, and the whole bezel will unclip from the dash.
I forget if there's 10mm or philips screws securing the radio into the dash...
Old Oct 13, 2006 | 12:40 PM
94_DC4's Avatar
Default Re: (B18C_EJ8)
It is phillips screws that hold the radio in place.
SVCoop
Honda Civic (2001 - 2005)
Jan 25, 2008 04:49 AM
drew.glaser
Nov 3, 2007 05:46 PM
ironman06
Sep 5, 2007 11:13 PM
c4virus
Apr 24, 2007 05:14 PM
flir
Audio / Security / Video
Oct 28, 2005 02:11 AM
